***THE BF4 BENCHMARKS THREAD***
Are all cores running maxed out at that clock? I don't think you'd beat its performance without going for a six core Intel CPU. But when Mantle comes along I expect you'd remove any CPU bottleneck at all on the 8350.
80-95 % on all cores.
High to medium settings with no AA is fine. Just make sure you update your drivers. :)
Eek, I'd dread to think. 5870 should be fine for medium settings fella. Don't forget most of the people pushing numbers in here are aiming for Ultra :D
I can live with that for now. I'm going to upgrade, but it will probably be the new year by then. Thanks.
Thanks for that really does show have more than 4 cores is going to be the norm soon. I wish Intel had cheaper 6 core CPUs, I don't really fancy going to AMD with an nVidia GTX 680 card... doesn't sit well with me lol
if amd were smart they would have new cpu's coming out next month :)
last i heard they delayed tho
their current look a bit too hot and power hungry for me
and there's only like 2 good boards? *throws bad grenade
That's what people say who have a bad job - Dear I could have brought Champagne tonight, but I had different priorities and got us some food we hadn't had in 3 days.
riiiiight... anyway back on topic think I'm going to hold on until after the game is released and see if it runs any better.
What do you mean pgi947?
pgi947; said:
Dont forget threads can offset the need for cores, sniff out a cheap 2nd hand 26/700k and you're laughing
these are the frametimes, but tbh they don't mean much to me.
i5 2500K @ 4.6GHZ
8GB Memory
Creative Labs XFI (Latest Drivers)
Nvidia 660GTX MSI Twin Fan @ +60MHZ/+300MHZ (42C Max Load) - Latest Drivers!
Windows 7 64BIT ( All drivers up to date )
Performance Problems : Lots of tearing in game, frame rate all over the place, lots of stuttering and jerking, even had the odd stall and stutter completely unplayable!
Settings : Tried Default Ultra all the way down to LOW
Partial Fix : Running in Windowed mode, but not acceptable
Useless as any server lag shows itself as a long frame time. Best off testing the single player side of the game for things like that.
tbh I didn't notice any stuttering and felt smooth to me, I think that long pause is where the tank blew up and then spawned me outside of area (stupid game)
I mean a good hyperthreaded chip can compensate for lack of extra physical cores, hunting for a hex core intel chip is always going to be an expensive venture, so something like a used 2600k (4 physical cores 8 threads) will work wonders as the load is offset to the ht threads :)
you'd find a decent 1155 board and a 2600k for well under £250 all in :)
The most powerful LGA1156 CPU my motherboard can take is an i7 880 which also has 8 threads, I'm going to see if I can pick one of them up cheap.
For single GPU's, I imagine that would be fine but if you intend on having dual or even a single powerful GPU, you will see bottlenecks. My advice just from this BF4 game is a 4770K as a minimum for ultra gaming. If more games companies follow Dice, a lot more will be wanting a beefy CPU as well as a beffy GPU (or 2).
Hope that makes sense and I would rather others confirm how they are getting on with their 3570K/3770K/2500K/5570K/4770K as well. This would give a better picture.
well for me it runs like poo
NVIDIA Drivers 331.40 running SLI GTX770
Max memory used was 1918,
GPU load average is 30%
CPU usage was high 90's
FPS seems to hover around 40-50
I had to turn down some settings but still very laggy did not seem to make much difference.
I know we are playing beta but seems to highlight my lack of CPU threads.
Not playable at all for me i hope Nvidia can sort out much better drivers on release.
Thanks for the info and I am assuming others are getting the same Ash. When you run AB, does it show your CPU usage across all 4 cores at over 80%? I am guessing this is why your GPU usage is so low.
@ Matt and others who are staying on the loading screen. I restarted my computer, did a repair install of BF4 and got straight on. Hopefully that has fixed it.
