***official amd 83x0 overclocking thread***
very impressive GinG considering your board dude here's mine
[/IMG]
not a lot in it really m8 slighty better cpu cause i upped fsb a tad, but no masses tbf good going m8 :D
Not bad for £570 all in :)
Got a few tweaks to go over the coming weeks, bet I can get it a little better but for what it took me to get here...about 30min in total not bad results :)
Edit - also wonder if running Vista will effect any of my scores??
1. i'd say you done great there dude few tweaks any you'll have a monster there
2. not sure on that one tbh
looking good though m8 i just tried your settings from you pic see what i get on windows 7 and post bk :D
im not sure you wanna see where i5 is dude lmao :p
[/IMG]
so this is m8 at 4.9 GinG say settings as you from your screen shots at 1.440v and maybe win7 does make a difference :confused:
that i7 is looking tasty though i will beat it, with a stick if all else fails lol
I need to tweak the voltage on the cpu I think, but off to bed soon knackered tonight after busy day at work!!
defo see if you can drop them but your making progress dude what its all about :D
Th0nt, I'm home tomorrow.
I'll give you a 4.8GHZ 4670k result.
That i5 on cinebench is a dual core with HT at 1.7GHZ lol.
Cinebench multi-threaded should be higher on an FX83 though.
Me too. I don't need another system but still really want to build one thanks to this thread.
@GinG - Vista will definitely be holding back your performance. Windows 8 is best for 8 core CPUs.
slight tweak to the fsb and that i7 can here me sneaking up on him and he's scared now
[/IMG]
temps are high due to my fiance doing her bit for global warming heating's on at 22 :eek: may as well stic tower in oven proberly cooler lmao
here's clock settings and temps
[/IMG]
really? much better than 7?
upgrade that instead of board as im now at 4.9ghz maybe?
my friends say they dont like w8 though
[/IMG]
[/IMG]
When did you go to 4.96GHz? :)
Windows 8 handles more cores better than 7, but it won't be massive. I expect Vista will be quite a bit behind though.
It's fine if you ignore Metro and just use the desktop - basically identical to 7.
