This is apparently what the pump sounds like. I'm more inclined to believe the one in the video is broken.
Very interested in this. What is your policy though if it leaks and harms hardware within the machine?
Its being run without liquid in it (You cant see ANY movement in there) its going to sound like a grumpy wasp
12 Minutes in, is it really this loud? Sounds like someones having a filling at the dentist!
Curious about this too snips, though i have my k2 on a 4.5ghz 4770k that hits 94c in p95. Therefore im very interested in the 240mm rad version. Also id regain my top most pcie slot which would allow me to go back to using my xonar DX audio card. Plus with red fans and coolant it would look rather snazzy along with my board.![]()
Agree, that's the main thing that is holding me back. If the temps are great or even match the 100i I would pick it up, that said the corsair warranty for any leaks is another thing to consider.
you should get a decent loop set up setter .mates just got his 4770k @4.6 bundle on water idles at 20c ingame 50c. he built it today.
Quite a high temp. Maybe you need a push-pull for that thick rad..
I'm pretty sure the 240mm is cooler though.
Just read in another thread, the cpu's in the extreme bundles are delidded and pasted with liquid metal. Explains the better temps as watercooling alone doesn't make a lot of difference over high end air cooling.you should get a decent loop set up setter .mates just got his 4770k @4.6 bundle on water idles at 20c ingame 50c. he built it today.
