The talk of the I5 being undermuscled is totally overstated (ivy and haswell). I'm running the game on custom ultra 4xmsa with a
[email protected] 1920x1200 maxed out CPU usage is 85%. (Spikes to 100% when you hit windows button) I use a single 7950 1200mhZ 1600Mhz mem. Min frames hit 40 Average 55 max 80....
GPU is 95-99% used
cpu is 85%
This game uses approx 10% more cpu resource than BF3. I get occasionall lag when Charlie comes down and generates a load of atmospheric dust, particles and litter. My advice is wait for
a) The game to be releashed before drawing conclusions
b) Be very sceptical about i5 being inferior to i7 untill we get proper scientific bench marks. Recall that historically that an i7 gives about 1 fps at clock speeds about 4.3-4.5Ghz.
My Bro has a cross fired 3930k six core cpu and the game uses all 6 cores at 60-70% with 2x7950's. Now if he uses HT with 12 threads or 6 physical cores only guess what...........FA difference maybe more heat!!! Go Figure.... (HT seems to perform better when the cpu isnt maxed out and has headroom to multitask)
Wait before you do anything is certainly my advice, especiallly when the game code, drivers are littered with bugs and faults ala its a beta beta...........
Anyway I'm getting another 7950 today and want to see this cpu bottleneck when running 2x7950's on an i5 at 4.6Ghz.
What performance can Mantle bring to us?
