Cheapest intel gaming build
24 Dec 2010
Anglesey
Hi just wondering before I go with amd. What is the cheapest intel build you can make? Im guessing it will have to be an i5?
I will be spending £500 on an amd build, butbam able to stretch a bit more if it means I can go with intel.
Machine only, no o/s.
Thanks, would they be considerably better than a fx 6300 with a 7850?
It pretty much depends what games you play. If it's stuff like Starcraft then I would aim for a Intel build as, sometimes, it can be quite a bit better but if you play games like Battlefield then the difference between a i5 and a 6300 would be small with a 7850.
