Is this on windows 8 ? as i don't know how your getting that type of FPSis 4 mins enough??
Windows 8 yes. I don't see what is so surprising considering it is SLI 670's.
I wouldn't say useless. I mean I still hardly ever see the framerate drop below 60 and if it does its only into the 50's and when there is **** loads of stuff kicking off in front of and around me. Trouble is, at these moments I can see GPU usage drop to as low as 60% on both cards so I know if I had an i7 I would see a big boost.....
However, seen as i'm getting mid /high 50's as the very minimum, im not going to be in a massive rush to go out and buy an i5. On the plus side, my 670's are keeping nice, cool and quiet and are barely breaking a sweat!
My SINGLE GPU setup drops to mid 40s-50s. Stays above 65 FPS on ultra.
3930k @ 5GHZ and my 7970 @ 1300/1750 HD 7970 on a 64/64 player server with ultra preset min43, max116, avg71
Edit: No stuttering i might add, butter smooth gameplay.
Dropping to mid 50s with an SLI setup and an i5 only shows how bad those components perform in BF4. My SINGLE GPU setup drops to mid 40s-50s. Stays above 65 FPS on ultra.
How about we see what the final game says?
We all know that an i5 will bottleneck sli/xfire in BF3 and BF4, but saying that an i5 is useless based on what can occasionally happen in the beta (which is an old build) with win7 is a bit premature and more than a little over the top.
I expect the final game will perform better on an i5, but the signs are quite clear that gaming is moving quickly to i7/8 core territory for best performance.
I have to disagree with an I5 being useless on BF4 and future games, far from useless. Yes they might not make the most of a high end GPU because of 4 threads, but I'm still hitting 60fps solid with the odd dip down into mid 50's with ultra settings across the board and 2x MSAA with vsync enabled. It's pretty decent if you ask me I'm very impressed. And I'm sure the full game will be better optimized, I'm certainly not rushing to the shops to buy an I7 yet. And I still have another 7950 sitting in its box next to me waiting to into my rig, theres more life in my I5 yet![]()
Min Max Avg
6 94 66.03
My FPS on 15 minutes of BF4 on the Low preset. It certainly feels much lower than 66 average; it stutters very badly.
Yep, this is proof that Nvidia is quite bad for BF4. In this case its probably the slow-ass memory bandwidth and small frame pool.
you're getting lower avarages than i did on Ultra preset.
Seems like it. My friend has a 7950 and he says he has no problems, yet I get better FPS than him on BF3. Really strange.
