HD 7990 performance
13 Jan 2013
County Durham
I purchased a gigabyte 7990 the other day and I'm a little disappointed in its performance in f1 2012 and 2013,I'm only getting an average of 71 fps in both games which I think isn't right as I was expecting over a 100 fps.i have fx8350 at 4.5 and 8gig of ram.Is there a way to solve this by changing any settings in CCC.
I don't play those games, but maybe crossfire isn't supported / needs an update? I seem to recall something along those lines before with regard to an F1 title.
Ok thanks for the help I just thought I should have been getting better performance so I thought maybe I needed to setup something in the ccc.
My scores were done with everything maxed out, so unless he's added some radeon pro extras or something, it's more than likely an xfire issue :)
It's not a demanding game tbh.
Actually, I just found an old benchmark that shows a minimum fps of 90 and an average of 107.
This was at 1100/1500, so you're definitely having issues there :)
Do you use the latest drivers (10.3 beta 2) & CF profiles?
Yeah used the latest drivers,what do you think could be the problem then because it doesn't seem right,on my 7870 xt I was getting around 90.
I don't know much about this game, but from a quick google search it seems to be one of those games that doesn't work well with xfire unfortunately.
Unless there's something different with the 7990, you should be able to enable/disable xfire in ccc.
Not sure about the caps, though I thought they were integrated with 13.10 drivers.
