it's because you can't finish.
seriously.
are you just aiming at the goal and blasting them? or placing your shots?
are you running straight at goal or at the right angle to score.
e.g. if i'm through on goal, i will make an angle for myself not just run straight at the keeper/goal.
i will use finesse a lot at certain angles yet placed power shots in others.
finishing is something which just comes naturally, i mean i have played guys online that could finish from anywhere with anyone they were that good at finishing.
there's only been a couple of matches where i have thought wow, that keeper had a blinder, but that's because i know how to finish.
the player's your using also matters a lot.
Gomez, Costa, IF Milito and Benteke are brilliant at finishing for example.
Kone on the other hand not so much, but his pace and power can be used for easy goals.
