- 12 Jun 2006
I'm getting one of these CPU's (haven't decided yet) and I am looking for a very good cooler. I plan on overclocking the CPU as much as I can, won't push it to it's limits though.
I was looking at the Corsair H100i but I am not sure if it will fit in my old (2007 model) case, a Thermaltake Armour LCS (which has watercooling). It may be possible to place the rad where my old one used to be (bottom front of the case). Also, there are quite a few complaints about the H100 so I am a bit scared.
Another solution is Air cooling, but I don't know how good is the airflow in my case. Here are all the fans I have in my case
http://www.thermaltake.com/products-model_specification.aspx?id=c_00000142
Is an Air solution going to be noisy/dump heat in my case? Which coolers would you recommend?
