Aah but Matt.. anything goes in a Beta![]()
True dat.
True dat.
I am now officially ****** off
I see in the Video settings that Ultra is now Ultra?
But they reset all my settings and key bindings.. nice one Dice!!!
Took me ****** ages to set that up!
 ... will wait an see what the full release brings before upgrading CPU/Mobo but fps range from 30s to 150+ but never too slow so as to overly bother me ... yet.Yes i had to do that as well. Annoying i still can't rebind certain keys. It won't let me use delete for reload as an example.![]()
 for now.They made a new config file under my docs->Battlefield 4 beta the old settings are still in my docs->Battlefield 4 I just copied mine over and hoped for the best as I can't be bothered with going into an empty server and tweaking it all again then editing the file in a text editor to bind the keys properly that can't be bound ingame.
Will i get delete working as reload if i do this? Cos as it stands it doesn't detect delete when i press it.
Yeah delete is keycode 211 - open the PROFSAVE_profile file and find/change the line to:
GstKeyBinding.infantry.ConceptReload.0.button 211
EDIT: If you mean del on the numpad its 83
	Noticed a few people saying this. Some that had it running smooth are now having issues. Whereas those who had issues are now running it fine. Typical dice, one step forward two steps back. Yet to try it myself as the patch is only downloading at 6kbps.Dunno what that patch was but from real smooth to feeling ughhhhhhh. Good work, NOT![]()
