It's nothing to do with "price gouging", it's the value of the software or service to the person using it. If I buy a £3000 piece of software that allows me to produce work that I sell for £30,000 or £300,000 then for me it's reasonably priced irrespective of the actual cost to produce the software in the first place.It's simply price gouging.
Generally it's priced so that the company making it doesn't lose money. Since very few people (comparatively) use 3D modeling software the price per unit is higher. It's the same with CAD stuff.
Because normally the things that are created in it are worth a lot of money and the sort of companies/people that use it can afford it and a comparatively small user base compared to mainstream software.
It's the same reason you pay more to see a top band in concert than unknowns or any one of a hundred other comparisons where the price charged for something is linked to (perceived) value to the purchaser, not based on the cost of production.
Perceived value could be based on anything from ease of use, to reputation, being an "industry standard" or 101 other influencing factors. Fundamentally like anything else in life a things value is based on what people are willing to pay for whatever reason, that's how a free market works.
Just found something called Blender which is free, not sure if I can learn to use it though.
Which isn't price "gouging", it's just pricing. The same applies for most things, including your labour in return for pay. Just because something is expensive, or sells for a lot more than a direct link to it's cost of production isn't necessarily a bad thing depending on the derived value gained by the customer. Price gouging is setting a price that is unreasonable or unfair, often because a customer has no other choice, even if the value (not price) doesn't justify the cost. By definition the phrase "price gouging" is inherently negative in tone which I somewhat suspect you know full well, my money's on you just being a a tad argumentative for the hell of it.You're taking my use as price gouging to be inherently negative in tone.
It's not. I'm not saying that the price they set is wrong or that they are maliciously taking advantage. I'm merely pointing out that they know people need the software and will pay for it, ergo they charge as such.
software is expensive to create
Poor argument. A lot of very awesome software cost, in money terms, essentially nothing to create. Software can cost a lot, if you pay good money for every developer-hour than goes into it, but a lot of software gets created without doing that.
I thought it was pretty obvious that we were talking about commercial software.
