- 10 May 2004
- Middlesex
With FTTP would they still run a copper cable into your premises for an analogue phone line?
just had new fibre cabinet installed close to my house, this was immediately reflected in the BT broadband checker saying I will be able to get up to 80mb when live.
Does this mean the cabinet is connected up etc or is the info just derived from proximity?
It must be a leased line quote or something because FTTPoD is only available in a few places at the moment, and it wouldn't cost anything like that to install.
It was FTTPoD I believe. The quote was a guesstimate from the company that is handling the rollout for Cornwall. It does cross a main A road however I believe all the cables to the cabinet are overhead and not underground.
I am moving house in about a years time so not too bothered - but I am going to make sure I can get atleast 80mbit in the new house - it is kind of a deal breaker unless the house is awesome.
A leased line would be lovely I read you can get them up to 10gbit up and down, no idea on cost though.
Most likely it's derived from proximity, since the most important factors determining speed for FTTC is distance to the cabinet and line quality.
The cabinet might be partially connected; how far along in the process depends on the location. Likely it's connected to the PCP and (possibly) the fibre line back to the exchange. It seems that the last (and most awkward) step for these cabinets is getting power to them.
What's the date given on the checker?
I'm not in a major city.
We have a 1GB barer and we are tiered to 200MB (1:1 - no contention) and we pay around £2k per month.
In a new build (FTTP area), everything goes over fibre.
Does that mean that phone lines will no longer be analogue?
The phone line is carried over the fibre (you plug the phone into a port on the OpenReach Modem).With FTTP would they still run a copper cable into your premises for an analogue phone line?
Hopefully we are just talking slightly different terminology here...No you don't. The open reach modem only plugs into your ONT for the Broadband. There is a cable from the ONT to the master socket (the ONT out puts a normal phone line signal and in my case they moved the master to nearby), the master now has a switch on the top of it for copper or fibre if you are coming form a house already provisioned with copper, when the phone line switches over you simply move the switch to fibre. The master and slave sockets all work the same way with regard to phones plugging into them.
The date WAS September, then March and now MAY 31st......
, I have noticed cabinets installed over six months ago for same exchange but also only last week saw lots of fibre getting laid in the town, so it seems they installed quite a few cabinets some time ago but actual fibre just going in now, in fact on way home from work I saw an openreach guy working at a new cabinet looking very like he was connecting it up. I`m hoping the latest date is not set in stone.
Sorry, one other thing: what do you mean by ONT?
Sorry, one other thing: what do you mean by ONT? Is that the OpenReach modem? I am not talking about the router, which is outside of this discussion. What I have been referring to all along (the OpenReach modem), is the device that receives a single input: the fibre cable, and produces several outputs: an ethernet connection (your broadband) which is PPPoE and plugs into your router (BT provides you with the BT Home Hub), and 2 phone connections (for up to 2 phone lines).
Cheers KIA. So ONT = modem (modulator/demodulator) which converts a fibre signal into a) PPPoE and b) voice.
