Might be useful if the first post is edited to recommend boards, and to warn against buying the 4+1 boards.
I'd like to see how the 6300/50 fare on 4+1 and whether they're enough tbh.
Yeah I am up for creating a simple table to reflect CPU+Board achievements. If you want to make it more complex then we could add RAM and voltages but it's how simple you want it to be.![]()
I'd suggest RAM brand, timings and voltage is pretty useful even though a lot depends on the IMC rather than the board. Other parameters ought to be CPU, clock, Voltage, board and revision and possibly bios as an option.
Sounds good to me ! Are there any non 990 boards that can run a 8 core?
I was so impressed with the 8350 system I built for someone using the Sabertooth board I have just ordered myself an 8350 with the Formula Z board arriving tomorrow.
I will be going from a 4770k to an 8350. Mad to some but more fiddle factor for me. Been Intel for a while and think it's time to try some AMD again.
Wish me luck...![]()
Farmerboy- any update from your friend, you not setup your trust either (email)?
