£1500 for AMD and intel
5 Sep 2013
UK
Hi guys just trying to get anther rig up and running and need a £1500 build both for AMD and intel. I got monitor windows etc just need the cpu gpu etc
Sorry used for gaming. So ye 1 build using the amd procsser and then anther using intel
Can i ask why when people build the amd processors they never go for the 9350 i think its called? Thanks
that cpu is just an over clocked 8350, with the v-core push up to the max. save £100 and buy a 8350 and over clock it. most of them do 5GHz with water cooling and that's more then the 9350 dose.
also the extra cost is not worth the extra power you gain for £250 you can get an i7 that will out perform it, and for £150 you can get an i5 that will out perform it. and let not forget on top of the £250 it costs to buy you need a cooler that can doo 200watt's so add £50 for that you now have a £300 cpu that only 5-10% better than the 8350(£150) at stock
Man thanks for that :) really well explained, do u know if any new processors are been released at all? in the next year or so?
