Hi everyone,
I used to be a keen PC gamer, but since working longer hours etc etc things have slipped somewhat on the PC front.
My system at present is a -
Q6600 @ factory settings
A Gigabyte mobo - Not sure on which, but was decent at the time
4 gig ram - Corsair I believe
Cosair 650w psu
MSI 7850 Twin Forzr 3 2gb
My Current GPU - Will this still cut it if I upgrade the CPU, Mobo and Ram?
Now I am not fussed on overclocking, all I want is a more up to date system that will play Total War Rome 2, BF4, the new F1 all at decent levels of detail. Now I will be playing this from my lounge on a HD (1080P) TV as I need to move the PC from bedroom.
I dont want out and out top end performance as I can't afford the top end of the scale - So my budget is around £250-£300 for the upgrade.
So my view - are the socket 1155's still worth going for?
Which would be best i3 or i5? If so the 3220 or 3240 for the i3's. Or is worth the extra 40 quid for the i5 - 3330? Or should I be going for the 1150 socket?
Also another concern is the level of noise - The case I am keeping is a Corsair Carbide 500 I believe. Its the one with bulges. Will this keep everything cool enough if I buy some decent low noise fans?
Sorry and one more thing is what CPU cooler should I get to keep the temp and noise down.
I look forward to peoples advice.
Thanks,
Ed
Cosair 650w psu
Thanks,
Ed
