- 21 Jul 2005
- Officially least sunny location -Ronskistats
OK not to worry.
OK not to worry.
sorry dude felt like i got ya hopes up been working on every ones specs what you think?
[/IMG]![]()
tweaks? ideas welcome.
more rig specs needed please, then i will edit first post to this![]()
Sounds good to me!
my ram timings are 10-11-11-28 @1.5V
Maybe we could have a benchmark leader board?
here were all about the red uprising against the blue devil, whatever your weapon of choice from the 83x0 range you'll find tips on how to tweak that chip into a fire breathing dragon. We have a great community of helpful guys and we all chip in as best we can to solve the teething problems of overclocking.
below is a list off members who have helped build the community and the thread and the specs of there boards, chip, voltages and ram to give newcomers a idea of whats commonly used with these chips
Farmerboy-86
cpu - 8350 @ 4.8 stable 1.44v
board - asus m5a99x evo r2 board
Ram - patriot viper 3 1600mhz @ 1.5v 9-9-9-24
Th0nt - helped push the thread and build it up and put up with all my questions ;p
teppic - helped push the thread and build it up
mxOrange
cpu - Amd FX 8320 @ 4.7Ghz
Board - Gigabyte GA-990FXA-UD3
Ram - 16Gb G.Skill Ripjaws X
ALXAndy
cpu - AMD FX 8320 @ 4.5ghz @ 1.38v
Board - Gigabyte 990 FXA UD3 rev 3.0
Ram - G skill Ripjaws Z @ 1866MHz 9-10-9-28 1T 1.65V
GavinG
cpu - 8320 Black Edition @ 4.5 GHz
Board - Gigabyte 990FXA-UD3 AMD 990FX
Ram - TeamGroup Elite Black 8GB (2x4GB)
GinG
cpu - FX8350 @ 4.9Ghz
Board - Asus M5A97 evo r2.0
Ram - Viper Black 8GB
pandem0nium
cpu - 8350 @ 5GHz
Board - sabertooth 990fx
ram team group extreme 2133MHz 10-11-11-28 @1.5v
nkata -
cpu - fx 8350 @ 4.75 GHz
Board - asus crosshair v formula
ram 16Gb ddr3
Also throughout the thread you will find many tips and posts of various rig setups and what works and doesn't
have fun and feel free to ask any questions and the guys and myself will be glad to help
here is what i have so far guys what you think? ideas? things to improve![]()
Mine isn't on there
I'm a newb to the thread but the info might help someone avoid my mistake.
A few too many variables IMO. much depends on the skill and knowledge of the forum member as well as the abilities of the board.
Board and power phases is OK but
A Simple list
Recommended boards
Marginal minimum spec boards
Not recommended boards
this could be added to or argued about much like the cool board on Top Gear.
Up to the OP really, I don't want to distract his thread, but I could edit my Post #2 to show a cool board.
Could be LLC try ultra high on the CPU and high on NB. Up the voltage then to 1.43 or maybe a bit more. The mobo you have got should be fine, I was benching at 5GHz on an M5A99x rev 1 but not prime stable. I was on air 1.47V and getting IBT stability at 4.8GHz.
Failing prime is no biggie if it does not throttle at normal work loads.
The following is in my opinion a list of good motherboards, competent motherboards and lastly ones to avoid if you want to overclock or even run an 8350 at stock.
Good motherboards should have good VRM's, 6+2 power phases or better, overheat protection, extensive and easy to use bios controls. With adequate cooling the CPU should reach 4.8 to 5.0GHz or better
Competent motherboards should also have good VRM's, 6+2 power phases or better, overheat protection, extensive and easy to use bios controls. With adequate cooling the CPU should reach 4.5GHz or better
Motherboards to avoid should also have 6+2 power phases or better but are likely to have 4+1, underdesigned VRM spec, or they lack esential bios controls. With adequate cooling the CPU may reach 4.2GHz but could also throttle at under 4.0GHz with load.
Under construction, you can trust me content![]()
