I run 670s in SLI and have seen no issues with the performance being on an FX. Having looked around my GPUs are doing exactly what they should do, even when the CPU is needed in equal measure.
I don't buy into this "Smoother on Intel" thing. That's just a childish way of saying that the Intel is better. Not that I'm having a go at you there, but I must have heard stuff like that a million times. You may find that once Windows is done updating and everything else that performance is better, but if not then any shortfalls are simply down to software support. Yeah I know that kinda sounds a bit rigid but at the end of the day when supported properly there are no FPS drop issues or anything else.
Have you tried Crysis 3 yet? give that a go, and, Far Cry 3 if you have them. I'm sure you'll be very impressed
