Is there a website that has all the AMD driver releases and scores for different games/benchmarks? Wondering if it's worth updating my drivers from 13.9 to the 13.11 Beta.
Very pleased with these Drivers. cooler, faster, better
1200 / 1550 is my new 24/7 overclock up from 1150 / 1500, might even run them at 1225 / 1575 24/7 they are so nice.
What GPU?
13.9 = WHQL
13.11 = Beta
It seems the 13.11 beta drivers have been taken down from the AMD website. I just get refered to their main support site now, even using their own direct link from game.amd.com
If you playing latest game's you should start getting used to installing the beta drivers.
It will be months before you even get, latest game tweaks with WHQL.
Dont install 13.11 if you play Fifa 14 constant Driver crash.. Now back using 13.10Beta2
This is why I don't use Beta drivers.
even still I still using a beta driver for the latest fixes.. So my point still stands.
Are you sure you don't have RadeonPro or any overlays causing the problem shanks? I know you and your SMAA/FXAA malarkey.
Didn't test that long mate, but fifa had issue with 13.10beta1 and Beta 2 fixed it Runs perfect on that.
13.11 driver crash soon as match about to kick off. Back on 13.10beta2 and runs perfect no other change.
The 13.11 Beta1 seem to have dropped my temps by 2-3c (which is always nice)
I've noticed this as well. I also need less voltage it seems as well. This driver is quickly earning legendary status imo.
