- 15 May 2012
- Louth, lincs
Use the latest 13.11 beta drivers Nick and try again.
http://www2.ati.com/drivers/beta/amd_catalyst_13.11_betav1.exe
However that crash message in my experience normally points to lack of vcore.
I assuming you're using MSI AB to overclock/overvolt your GPU. This does not work in BF4 since its 64 bit. Your clock will initiate but the voltage wont, so the GPU crashes and the driver restarts TADA ERROR. Use sapphire trixx for overvolting when playing BF4.
on 'em matt, and knocked multi down 1 but using same vcore, which is a lot!!
Actually it works fine for me, to change vcore on my HIS 7950's using afterburner.
I meant gpu vcore. Though until you get things stable id have everything at stock.
That can't be true because if it is my 7970 is going 1200/1700 in BF4 on stock volts
anyone else getting regular crashes, gpu at stock, even upped the voltage, dropped cpu multi, is it the game or something my end???
Yes, its a BF4 bug, supposedly fixed with the last patch, to be honest i have not had a crash since then but in the patch thread on the BF4 forum others are still reporting crashes.
plug.
That's called Titan Syndrome. The server can't keep up with the throughput of those truly majestic, magnificent cards.
Whilst on the subject there might be 3 up for sale very cheap in a couple of weeks.
plug.
