Hi,
Just converted from my trusty old Core 2 Quad Q6600 @ 3.2Ghz, ASUS Rampage Extreme x86 and GTX560Ti SLI.
My new system is :-
AMD FX8320
ASUS Sabertooth 990fx
ASUS HD7970 Direct CUII
Just managed to get them setup last night after RMA a one motherboard.
As a mild Overclocker I just upped the CPU ratio to 20 this morning and ran Prime95 for an hour or so and all was stable at 51 degrees on the CPU and 39 on the core. At Idle the CPU sits at 30 and core at 17 (If what I am reading correct.
(Using AI Suite for the Thermal CPU and Core temp for the Cores)
What kind of overclock can I get on this board/CPU combo using Corsair H50 cooler?
4.5GHz is doable on just about every cooler with the right settings. The board is very capable of overclocking, the CPU varies but a lot can get to 5GHz. Have you just kept everything at stock and increased the multiplier? I'd first try to see how high you can go on stock volts, though you'll want to change the LLC setting.
it's lowered my temps by 20c so I'm hitting 52c in LinX (which makes it hotter than any other stability test I've tried).
