- 26 Aug 2004
How do you get those graphs in the overlay sir?
Big Dave stick this user.cfg file in your BF4 game folder.
This will give you a in game fps monitor and the cpu/gpu performance graph by default.
http://www.sendspace.com/file/z0yzde
Thanks Matt will do
As promised... Single Titan results. Not sure how these are to be compared to my original results as that was before the most recent 54MB patch.
SNIP
I don't believe you'll find a single card currently (290X or a titan) that in all situations at 1080p or higher at the highest details will be able to keep minimum FPS at 55-60 or over at all times. Maybe with a more polished game or drivers its possible but not currently. The game is pretty hard on gpu's atm.
Thanks Frosty. Good results nonetheless.
I was right in my original comment.
I'm actually surprised at how much more demanding this game is over BF3 tbh.
I can't even play the beta, I just see a loading screen
So Greg's doesn't count? You do like cherry picking. Neither are invalid results but you can't just write off peoples results because they don't fall in line with what you believe.
That's fine Greg but you need to read what i said with my original comment. You took it out of context. My original comment stands and is correct but you took that as i was accusing you of lying. As i said i never doubt that in your 5 minute runs your results are accurate. I'm talking about the bigger picture in all situations. I don't believe one single card has the grunt to maintain 55-60fps at all times.
I will say though I do tend to agree that its pretty easy to go below 50 fps with a single GPU. Just depends how crazy things get![]()
If Greg managed to cover all situations in that 5 minute bench then great. I think we all know thats not the case though.
I'm sure if you try hard enough you can avoid the brief drops to low fps by avoiding the incidents that cause it to happen in the first place. But then thats going against exactly what i said.
Unless said otherwise I'd trust Gregster to get in everything that makes it a representative section of gameplay. As I said with my heart rate example, just because it's a shorter sample doesn't mean that the results are not as useful as a full map run.
LtMatt said:I don't believe you'll find a single card currently (290X or a titan) that in all situations at 1080p or higher at the highest details will be able to keep minimum FPS at 55-60 or over at all times. Maybe with a more polished game or drivers its possible but not currently. The game is pretty hard on gpu's atm.
As we can see from the Gamegpu graph a 7990's minimum fps in BF4 are much higher than a titan in BF4. Yet even the 7990 will see that sort of drop during those intense explosions. I find it hard to believe a titan won't see that as well. Of course it will.
I'm sure for 99.9% of the time it will be above that though obviously, but this is worst case scenario here.
Well my results say different and your opinion is duly noted.
.None of which has any reference to a representative slice of gameplay? As I said, I would trust Gregster to capture this as he's not exactly a newb (well he is at BF4 but that's a different story).
I just think you're just too bothered about being right or wrong. There is a grey area still.
I never said it did, nor was it meant to. This was simply that no single gpu can keep it above 60 fps at all times in the most intense parts of the game, as per my first quote. As has been noted by Frosty, triggering these events its quite easy to make the fps drop below that limit.
its something to debate i guess, only ronnies animal crackers on tv
i think thats right, at this minute 1 gpu cant on them settings, in all situations, but updates are improving the game, in 2months time even a 280x with a i5 could...maybe
i dont like crossfire or sli much bcos i play some weird old games, so it does matter to me that they start making some better gpu's
