All you would see is me selecting deploy![]()
Lol. If you do it ill do one as well Scotty.
Lol. If you do it ill do one as well Scotty.![]()
Hell why not - I game for a laugh
Will try to sort this week
Once I've re homed my Titans
Ah come on man im only messing, you should know that.
She did do well. Fair play to her for agreeing to stand there and do it.
As for the fps, 3:33 and 4:44. I've got eagle eyes.A couple of others as well but those were the lowest. Not bad, but as i said none of those situations i originally referred to which you took offence at.
In truth, it isn't the best gameplay vid because you can't really see what is going on but at the start, the tower was coming down and I flew round the corner to try and get it on film and just caught the end of it where the smoke and dust all plumes up and as you know, this makes the rest of the round look poor visually.
It does give peeps a rough Idea and I noticed it drop to 54 at 3:33, so your statement about dropping under 57 fps in all situations was correct and even with Trisli GPU's, it seems that these drops can't be avoided in the Beta. Maybe the full release will be better but as far as comparing this to BF3, I don't see much more demand required.
Textures possibly missing? Not full ultra being applied yet? Pass but for me, gameplay is good. I much prefer the 32 man domination and none of that crappy dust/smoke when the tower comes down and quick action shooting is needed and less snipers.
I'll drink to that Greg. Good vid though man and you'll be able to laugh at me and my fps drops when i do mine.![]()
Cool beans.
I might have to run at 1080p as ill probably record straight from the pc. My monitor is glossy so if i record using the camera all you'll see is me in the reflection. I also like to game naked so that won't be happening.![]()
Pen and paper at the ready and super slo mo will be used![]()
Thanks for that lovely image that you've just put in my head -![]()
I'll run fraps benchmark at the same time as well as the built in game fps.
? To the built in bit
Stick this in your user.cfg in the BF4 folder.
PerfOverlay.DrawFps 1
PerfOverlay.Enable 1
PerfOverlay.DrawGraph 1
I'll have the performance overlay and the fps counter running all in different corners. You'll see, live and feel every cpu spike and fps drop as if you were there with me.![]()
I forgot that afterburner does not work with the BF4 Beta as its not a 64bit application. Not sure how im going to record some gameplay without taking a significant fps hit. At least with afterburner you could use a different codec to reduce the strain.
Any suggestions? All i can think of is fraps but that takes up loads of space for a video when i only have 35 gigs of space free. Not to mention the performance hit from it is massive i think.
Just tried recording with fraps using these settings, but it seems to lock the frame rate down to 60 while playing. Anyway to get an unlimited frame rate?
Change the video capture settings to custom and say 200 FPS.
Frames, Time, Min, Max, Avg,
49649, 848389, 31, 107, 58.588
Not very impressive at all, get W8 it'll probably help. Which GPU drivers are you using?
