Pod coffee machine for ~£100
Man of Honour
12 Jan 2003
UK
Hi all, looking to buy a coffee machine as a christmas gift this year, to the value of about £100. Just after some advice if possible on good makes and models to go for?
anything in particular to look out for?
I assume the actual pods don't cost too much and can be bought from any supermarket?
ps I'm not a coffee drinker myself!
are nespresso pods different from "regular" pods? are they specific only to nespresso machines?
any reason why you recommend those please?
i think the nespresso pods only fit the nespresso machines
ages ago i looked in to these and they were the make everyone was recommending
quality and coffee are great
though at work i have a bought a machines that takes powder instead of pods which drops the cost down to about .5p - .10p a cup
Another vote for a Tassimo. As others have said Tassimo do deals every so often.
I got a Tassimo machine for £30 as part of a promotion from Costa Coffee. The machine sold elsewhere for £80 rrp. When you registered the machine with Tassimo they give you a £25 voucher for coffee pods from their online shop.
I'm sure they'll run something similar on the run up to Christmas.
Nespresso >>>>>>>>>> Tassimo in terms of actual coffee taste. Totally different league in my opinion. However you won't be able to make lattes or hot chocolates etc with the ones in your price range, just espressos and americanos. So if buying for someone who likes that kinda thing the tassimo is probably the better option.
If buying a Nespresso wait until mid Novemberish as most retailers offer a £30-£50 voucher for free coffee capsules (value based on how expensive the machines are).
In answer to the original question, yes the pods will only work only with the system/machines they are designed for. You essentially have on the market:
Nespresso (Nestle)
Nescafé Dolce Gusto (Nestle)
Tassimo (Kraft)
Senseo (Philips/Dowe Egberts)
I've used all of them except Senseo, which doesn't have many variations anyway.
Dolce Gusto & Tassimo are good if you are interested in drinks other than Coffee, as they will also do teas and various other drinks. They have also started bringing out branded versions, like Starbucks & Costa pods, though I don't feel that means very much personally. They also do pods which have long-life milk in them, in order to create Lattes, Cappuccinos and Hot Chocolates.
Nespresso is purely about the coffee and in my opinion is superior to the other systems in that respect. Its also the reason they have so many different blends of coffee compared to Dolce Gusto which they also operate. While Nespresso doesn't have milk pods, you can buy machines which have a milk frother, or an automatic milk machine, like the Latissima which I have. They also introduced pods this summer which have a slight flavouring, so for example you can have a Vanilla Latte. One downside though is that Nespresso pods are only available online or in their stores or concessions. Where as the other pods can be picked up in most supermarkets.
So really it comes down whether the person you are buying for is interested in other drinks and how much they love coffee really. Also where they can buy from. If its an old person who doesn't use the internet and isn't in a major city, then a Nespresso machine might not be ideal.
thanks for all the feedback everyone, that's appreciated. Will look into some of the suggestions
thats of interest potentially, although when i had a look round for Starbucks pods i could only see them for their own Verisimo machine range. Are you saying you can get Tassimo Starbucks pods then now?
Bear in mind that the non-Nespresso pod based coffee machines require the use of 2 pods for milk-based drinks (one for the coffee/chocolate and one for the milk) so end up costing twice as much per drink and obviously aren't using fresh milk either.
Though they do come in the packaging for both parts of the drink, but are obviously more expensive than non-milk drinks.
My parents have a Dolce Gusto and the milk drink in that is a little better than the Tassimo milk pods are, but I still end up putting real milk in any of the drinks when I create them.
I personally have a Nespresso Latissima, which has a milk carafe that you put the milk in which then attaches to the machine to make a cappuccino or latte. You then detach it and put it back in the fridge. Then needs a clean every now and again depending on how often you use it.
Its more than £100 though.
I did used to use a proper espresso machine as I like my coffee, but it was a lot of hassle. Obviously you can get proper bean to cup machines without much mess, but they tend to be far more expensive.
why the pods?
for that kind of money I would be looking at a second hand proper machine that you can use any type of coffee in
Ease of use, as I explained above.
When I used to have a proper espresso machine, it was a bit of a hassle, say to make a coffee before work quickly, so it ended up becoming something I only bothered with at the weekend.
You need to switch it on & let it warm for a few minutes. Grind coffee beans in a grinder, unless you have some pre-prepared. Tamper it, put it in the machine and actually make the coffee, then clear out the coffee grounds, which can be a bit messy. If you are doing milk you also need to let it warm longer so it gets hot and you have the steam pressure, you then obviously need to wash everything up there as well.
As I said before, you can get Bean-To-Cup machines which do all the grinding and minimise the mess, but these tend to be quite expensive for a decent one.
With a pod machine, its quick, simple and clean. With Nespresso the coffee is also decent enough that I'm not missing having my own beans and blends of coffee.
lol, i should have seen this earlier.
i have tried most of the pod system. (im lucky enough i have a number of offices, so i can put a different one in each and in the process, test it for myself :D)
in short, it boils down to this:
for ultimate taste, go for a E.S.E system if you want something bigger than standard espresso. otherwise, go with Nespresso.
i will briefly explain each one i tried:
i started off with Dolce Gusto a couple of years ago, got it from costco on the cheap. but after a few weeks i notice the coffee/drink really doesnt taste that good. it lacks the polish/relax/feel good factor. the milk pod is good, but it's definitely a milk powder type milk. some of my people dont like it at all.
then i went onto Nespresso, knowing that it makes no difference to taste which ever machine i got. i bought their one of their cheapest design by magimix just for the test. taste is definitely very good. but it only does one size (well, two if you count lungo as well). another down side is, unlike other machine, it doesnt offer milk pods, so you need a fridge. In office environment, some time is hard to have a fridge in meeting rooms.
next one up is Tassimo T55, i like how costa and starbucks (at the time, but now they switched) makes pods for them. might just be brand effect but clients and visitor are often find them quite posh. bigger sized coffee definitely taste above-average. espresso is not so great. i think it's down to the pressure (less than 15 bar+ used in other machines). and it splashed everywhere when it makes foamy drinks. they also offer a better milk pods, taste abit creamy-ish (which some people don't like). strangely, the tassimo is the only one that ever jammed out of the lot. but it was no big deal, just pull the plug and empty the whole lot and start again.
then i moved house, so i bought a ESE machine from delonghi. it has the steam forth pipe on the side for making very decent forth. this one is by far the best tasting machine as it uses ESE pods OR any coffee beans you happened to have in the house. for home use (when i actually try to relax over weekends, i think this is most suited). the only downside and it's a big one, cleaning up after use is a total nightmare and prepare time is also very long.
shortly after i got my own machine, the philips one went on sale, so i bought one from viking office supply. while it's not bad, but choices are very limited and soem times hard to find the pods. i dont rate this one very high. it didnt even give me that "special toy" moment, i gave it away to one of the guys in the office.
about a year ago, starbucks left the Tassimo system and joined the K-cup system which originated by Aldi in germany. It was originally sold by Tesco as one of the cheaper alternative too nescafe Dolce Gusto. Once Starbucks joined, they repackaged it and sold it for a lot more. taste wise, it's not too bad, but again, not much refinement with the drinks. i think starbucks changed the formula, so it doesnt quite taste as good as it did with Tassimo.
few months ago, i got a new office, so i went and got another one which is fairly new to the market, the new illy Francis range. i got the Y1, and it's quite a looker. so thats the one i have now currently in my room. taste is fair, not as good as their previous system ESE, but fair abit easier to use. the other thing is that, this one actually give very hot coffee. most of the other ones will not give proper hot coffee.
at one point we actually rented one of those commerical version of nespresso machine. it uses coffee discs rather than pods. to me, the taste is the same. i think they re-dsign the pod to be a disc so in a busy environment, the waste is more compacted. but given the cost, i dont think it's worth it. i much rather buy a couple of cheapish ones from the normal range and use the pods.
EDIT: i dont think £100 is enough for bean-to-cup machines. i think they are definitely a level above pod machines (if people can cycle to beans fast enough, rather than lettign the beans sit in the loader for months)
