The way I say it the Matrix is guaranteed to 1100mhz, some 7970 won't even do that stable if you get unlucky... At £220 the Matrix is a bargain even if it hits a wall at 1150mhz, most people who buy one probably won't be overclocking anyway.
Reference cards with ref coolers wont come anywhere close to matrix if the chip is identical, and that is ONLY because of the cooler as tahiti is temp sensitive. If you meant ref cards with any aftermarket cooler then its just a blank uneducated claim.
No it's not.
We employ one of the worlds best overclockers, 8Pack!
He test all the hardware on top-end and he ranks the Matrix and Lightning as the best 7970's for extreme clocking. He has of course extreme cooled reference cards at launch, he still got better results with Matrix and Lightning.
For me if 8Pack says these Matrix and Lightnings are better, than they are, conversation over.![]()
Matt's old ref 7970 could bench at 1340+ with an accelero and another guy here can do pretty much the same on the stockhairdryercooler.
Should I be mad that my identical card can't match theirs even on water?
My last 7950 on a ref 7970 pcb couldn't do more than 1150 even with uber aftermarket custom aircooling.
It's a lottery whatever way you look at it.
Fancy pcb or not, there are no guarantees. End of.
That is the only thing the matrix is better for, extreme cooling. I never said it wouldnt do that well.
No? Then by all means proceed to educate me, Oh enlightened, vague and angry one.
Why don't you explain then, the way your posts come across, its as though the card jumped out the case, grabbed a knife and cut your arm off!
Since when does 1100 give JAW DROPPING "GAME THRILLS" That any other 7970 wouldnt at similar clocks? It also gives the impression that other cards wont hit 1100.ROG MATRIX HD 7970: Jaw-dropping game thrills thanks to extreme overclocking
This just doesnt work at all. The buttons do nothing, it only changes a couple of lights on the PCB. Another lie.TweakIt
Instant voltage adjustment
Again, this did nothing at all.Safe Mode
Does NOT matter until you're pushing 1600+ on the core with LN2 or Dice. OP is gonna do that?DIGI+ VRM with 20-phase Super Alloy Power
Well this is just absolutely useless. I had a bug with it where the text would not show, i couldnt read what i was doing. The profile or "Flash feature" does not work. The LLC does not keep the voltage from drooping. You'll have to manually set your volts and OC every time you reboot. Some will say "ooh but you can use AB or Trixx to change clocks to save it" Well you still gotta use GPU tweak to change the volts to run said clocks because NOTHING ELSE IS COMPATIBLE WITH IT. Isnt that a PITA?GPU Tweak
The world's first graphics overclocking tool with loadline calibration and VRM overclocking.
And none of your reasons are anything to do with how well the card overclocks according to your previous reply.
Lol this is the second 7970 thread you have hijacked and dragged to the gutter this week, and both of them are littered with deleted posts, you really are an asset to these forums, +1 internet to you good sir!!!
You cant buy a non reference card and complain that specialized blocks are harder to come by and also more expensive.
The fact that it has better power management and higher quality components allow it to achieve higher OC but as its been said plenty of times in this thread, nothing can guarantee overclocks and if the GPU hits a wall before it makes full use of the better power management, then that is hardly the fault of Asus, since they do not guarantee it, because they cant.
Also i am sorry to tell you Rangerjr, but Kevin Bacon was in footloose.
