Because i PAID more for it to OC more. If i had paid the same as a ref cost at the time, i wouldnt make a big deal out of it.
Four Asus Matrix Platinum 7970s
Four waterblocks
Total 1200 quid
Totally anihilates most setups
Fantastic bang for buck
Or you could buy one Titan or R9 290X plus waterblock lol.
As you've said: "That may or may not matter now because its now priced accordingly"
The fact still is that your card wasn't necessarily representative of the majority.
Whyscotty's card doing 1345 proves that.
It represents luck of the draw.
Who said it was?
Lmao
Rangerjr1, Matrix and Lightnings are more likely to be better than references overclocking wise hence the premium in addition to the factory OC. More likely is not the same as guaranteed. You got unlucky with the Matrix and lucky with the reference. That's all there is to it plain and simple so you can't represent for every Matrix out there.
You dont get it do you.
im also a bit miffed, ordered a asus dc11 top on tuesday for £227 as the matrix was too dear at £260, then a few days later, the matrix is going for £222.
Wow, what happened to this thread overnight? I was only after a bit of advice lol.
P.S I still haven't chose a card yet.
