....it would seem you've done it, sweet, this doesnt work for other sites though, can't get youtube or antyhing this way
"..cache..." ?
Why are you trying to use youtube at school? Are you normally allowed?
Blocking Google is insane, what are the IT folks thinking. I guess Wikipedia is probably off the menu too just in case you might learn something.
Looks like you will have to use logmein or something like that via web interface and use your PC at home to get anywork done!
I can understand why youtube might be blocked in case your all watching family guy or something else!![]()
It's because you copied my sig, your admin went nah that ain't on.
Maybe someone in your class googled "Hidden areas to place a bomb in a Peugeot 206"
it would seem someone knows their history.
This actually happened in my street, had to be evacuated from my house as there as a bomb under my neighbour's.....peugeot 206......
I just picked a car the average N.I resident would be able to afford.![]()
ALL OF THEM are blocked![]()
I highly doubt that al the proxies have been blocked. At school, before we found out about stuff like ultrasurf, we went through hundreds of proxies. usually they were blocked within a couple of days, but as soon as one was blocked we found another.
I suggest you look in the depths of whatever search engine isnt blocked on your computer for phproxy. I'm talking something like 50 pages in (and not the pages right at the end of the list of links to pages of the search either)
Also, try using a webpage translator. They also work like proxies. on a similar line, those websites that 'translate' a website into something silly like pirate speak or whatever might work too
Set up your home PC as a web proxy, I.T. dept can't ban it because you can change the ip address at will, they'd have to create a whitelist.
