Hyburfag
Caporegime
29 Jul 2011
In acme's chair.
Use EKfittings, get coloured tubing and I've got some coolant you could have. Buy 2nd hand D5 and 2nd hand rad/fans.
Noooo, has to be the fancy fittings :p you have no idea how much I struggle with compressions as it is xD
I want clear so I can see the movement of the fluid and see it pass through the block. Plus I could flush and replace the coolant with a new colour :D
Was planning on buying used to save monies anyway, thanks for the offer of coolant. :)
I've got 2L of red and 2L of pastel white, put them together I'm sure you'll have a lovely pink (don't think you can mix :() If you run colour for long enough you'll probably stain your tubing to a degree anyway and it's only cheap so you may aswell replace it for each different colour.
