Would you really spend £750k to generate £2500 per month?
You guys do realise the houses are STILL worth 750k which can be recouped at a later date.
After 10 years you'd have say 400k cash with interest, probably more and the houses will probably increase in value anywhere between 850-1mil.
THe real way to do it is buy a run down house way under market value, do it up, generate some rent for several years, then sell the house whenever the market is good. Buy again when the market is down(if possible) and do the same.
In the same period that money at say 5% interest would be worth maybe what 1.1-1.2mil if you never touch a penny of it?
30k is more than most people make in a year, god knows what the average is these days, its well above it and assuming you're living with mortgage/rent costs then that goes even further.
Property has worked for thousands of people for hundreds of years. basically getting a return of a higher yield than you can get from interest in a bank is relatively easy.
A worthy investment. Would only take him 25 years to regain the 750,000 invested.
In 25 years with compounded interest you would have massively more than 750k cash and as above you'd still have the houses.
After 25 years at 5% interest £2500 a month is a touch under 1.5mil, and you still have the original value of the houses which could(but unlikely) to have gone down and could have gone up substantially. You'd realistically expect the house prices to go up at least 15-20% over that time.
The reason real estate is good is, rent basically didn't go down during the recession while the amount that 750k could have made in the bank DID go down significantly. Real estate has stood the test of time and has worked in almost any economy with a strong return.
Unless you're buying land and building houses, which can take years and a fairly large chunk of cash upfront, then buy to let is about beating the interest rate the same cash could make in the bank. 5% more interest over 25 years well.
£750000 savings in 5% a year interest over 25 years nets you 2.6mil, at 10% interest over 25 years you end up with 9mil.
Every single percent has a huge consequence, if you get a 7-8% return on your investment you are essentially making millions more over 25mil than sticking it in the bank, if a recession happens and drops interest to 1-3% while your houses are still bringing in 7-8%(a really good buying price can get you higher still) which doesn't dip in a recession is worth SIGNIFICANTLY more over time.
When you factor in things like inflation. 750k vs 25 years later and having 2.6mil isn't going to be massively different tbh. However 9mil 25 years later, that moves you from doing pretty good to rich, 750k at 5% untouched for 25 years doesn't change an awful lot.
This is all an aside, most peoples goals is to use that 2500k a month to secure a mortgage on another property, then rent that, then some months later building up a bit more cash you get another property, and another mortgage. After 10 years you've gone from 5 houses at 2.5k a month income to 15 houses and 7.5k a month interest and something you can tend to run part time on top of a normal job. Long term investment and someone could retire 5-10 years early and on top of their pension they can still be bringing in another 100k a year.
