Saw that on pcper the other day Greg and wondered why nowt was made of it. There would be a 1000+ posts flaming thread by now if the other side had dared![]()
Maybe but it just seems strange. Maybe AMD will be selling leads at Apple type prices.
Who cares, it's a GPU not a soundcard![]()
Are you sure its not a sound card?![]()
AMD are placing an apple like hardware check chip on the 290/X that blocks the Audio signal if you don't use the lead that comes with your AMD GPU. Not sure on the effects of this.
It is at 50:55 in the video.
How the hell did my post get ahead of your last one Suarez, when it was already showing before I replied?
They actually said it has to do with blocking non-bundled DVI-HDMI adapters. If you desolder the chip or in some way disable it, you get no audio too. That's whack.
The only explanation they offered was "not wanting to support other peoples' hardware" but I think it's inexcusable.
So if you use a different DVI cable, you will get all your audio blocked? I hope they supply lots of leads then, as the multi monitor uses will be ******
Or have I misunderstood?
Are you sure its not a sound card with a GPU as a bonus?![]()
Damnit. Just seen I put 'uses' instead of 'users'...Rusty will be throwing rotten veg at me now via email
I can see I will loose this one![]()
lose*![]()
Damn you - I wanted the honour!![]()
