will be a week or two though.Sounds like the offset affair the Gigabyte board had. Strange, I would have thought the bios would be very similar to the ROG board. Any screenshots of the bios?
It's yellow in that SS, but the values are I think 0.0644534 type increments upto 1v.
nkata getting your toes wet with some serious WC kit nice!
. I have some tube and coolant left over from a previous loop.
. I have some lube and coolant left over from a previous..
So when you actually try to type your voltage in the box with yellow writing (e.g. 1.5V), it doesn't let you?
It didn't but I may have overlooked the manual setting; it definitely had the + - tabs and I would have preferred to just see the value you were submitting.
anyways
edit: ran the old cinebench R11.5 to compare to UD3 score.. both at 4.9ghz the CHVFZ is scoring lower. 8.05 vs 8.39 achieved with the UD3![]()
Scores between different versions of the benchmark can't be compared.
i ran the older version, same as i used for the UD3 board
Great stuff Thont, you need to beat that 4770k score I think!
That 4770K isn't accurate just so you know.
