The CCNA/Cisco Certifications Thread
1 Mar 2004
Kent, UK.
Well had my first day on the ICND1 course and I can't say I've really learnt anything new that I don't already really know. Looks like the ICND1 has changed quite a bit this year with a lot more content than previous years. Enjoying the course so far though!
Who are you doing you ICND1 through? What sort of stuff did they cover on the first day?
1 Dec 2004
S.Wales
Guys, just a quick one, whats the best way to emulate a switch in your lab in GNS3, I just realised they dont official support switch (catalyst) emulation, so far I have some 2691 routers in my GNS3 Lab so far.
There are some basic switches in GNS3, but are literally a dialogue box, choose your switch port, choose your VLAN ID, choose the mode all from drop down boxes, and thats it, nothing like configuring a catalyst switch via command line.
EDIT: for now I have just added a 3745 Router IOS image, with a 16 port switch module so I will use this to emulate a switch
OP
13 Jan 2010
A box in the Astral Plane
GNS3 can't emulate Cisco switches.
You can install an EtherSwitch Module in to a router and it will behave similarly to a switch, but not exactly the same.
Personally I bought a couple of real switches, then bridged them in to GNS3. Seems to work just fine. :)
On an unrelated note: CCNP Switch exam scheduled for the 31st of this month!
1 Dec 2004
S.Wales
It's OK, I have found a way to get around it
Code:
SW01#show version
Cisco IOS Software, 3700 Software (C3745-ADVIPSERVICESK9-M), Version 12.4(25c
Code:
SW01#show ip int brief
Interface                  IP-Address      OK? Method Status                Protoco        l
FastEthernet0/0            unassigned      YES unset  administratively down down
FastEthernet0/1            unassigned      YES unset  administratively down down
FastEthernet1/0            unassigned      YES unset  up                    down
FastEthernet1/1            unassigned      YES unset  up                    down
FastEthernet1/2            unassigned      YES unset  up                    down
FastEthernet1/3            unassigned      YES unset  up                    down
FastEthernet1/4            unassigned      YES unset  up                    down
FastEthernet1/5            unassigned      YES unset  up                    down
FastEthernet1/6            unassigned      YES unset  up                    down
FastEthernet1/7            unassigned      YES unset  up                    down
FastEthernet1/8            unassigned      YES unset  up                    down
FastEthernet1/9            unassigned      YES unset  up                    down
FastEthernet1/10           unassigned      YES unset  up                    down
FastEthernet1/11           unassigned      YES unset  up                    down
FastEthernet1/12           unassigned      YES unset  up                    down
FastEthernet1/13           unassigned      YES unset  up                    down
FastEthernet1/14           unassigned      YES unset  up                    down
FastEthernet1/15           unassigned      YES unset  up                    down
Vlan1                      unassigned      YES unset  up                    down
SW01#
This should be good enough :)
1 Dec 2004
S.Wales
That is an EtherSwitch Module inside a 3700 series router. :)
Bear in mind there will be some differences between the ESM and an actual switch. For the CCNA though it's pretty good.
Aslong as I can do the main functionality of what is asked in ICND1 and ICND2 this should be ok
1 Dec 2004
S.Wales
There are quite a few people who just use GNS3 so you should be good to go.
If there are any missing features then I could allow you to remotely access my lab for 2-3 hours at a time if needed
for anything that can't be done in GNS3. :)
How generous :) thanks will let you know if I run in to anything.
I have been using packet tracer really but thought it would be good setting up a spare PC under my desk as a LAB machine, and installing GNS3, not just for the ICND1 and 2 revision, but so I can also lab in work whilst testing stuff. I can RDP to it in work or at home.
Xez
Xez
24 Jun 2005
Lincolnshire
It was mainly network topology's on the first day. I'm currently learning this with QA and the teacher is brilliant and explains things very well.
My main weak point is subnetting and variable length subnetting. Everything else I'm comfortable with. Learning IPv6 tomorrow but it isn't as in depth as it is in ICND2.
1 Mar 2004
Kent, UK.
That's good to know, I'm booked in with QA as well.
10 Jan 2010
Reading
Its amazing to hear that something from QA is good. From the apprentice training aspect they do, its atrocious. They encourage using brain dumps... the vce software or whatever it is called is on the computers as standard and there are plenty of dumps in the network share.
(Maidenhead and Reading centre)
1 Dec 2004
S.Wales
I am trying to work out a good base topology to get me going, does this look ok so far? obviously there is no links yet. I want to create a few clusters of host machines in different VLAN's.
Can anyone tell me if I am missing anything or needs adjusting, I will be creating a few different topologies based on what I run in to, but wanted to get something set-up.
There is no links yet
8 Jun 2005
London
Looks good for the basics, you're not going to be 100% up to date with switching using the etherswitch modules, but it's better than nothing - I also can't remember whether spanning-tree works properly or not, but you'll be able to configure and understand basic VLANS.
As for for the routing topology, you could configure a mix of ethernet and serial links then focus on basic routing, addressing, ACLs etc, (I think they only test RIPv2 in ICND1) so you should be able to cover most of that stuff off with that topology :)
OP
13 Jan 2010
If the ESM's support STP, you'll want a few switches that are linked together for that as well as a couple of other things.
You'll also want a frame relay switch for some of your labs too. :)
In response to V-Spec's comment on RIPv2 in ICND1, they've removed RIP and introduced OSPF. A mixture of serial and ethernet links as he suggested is a good idea. :)
1 Dec 2004
S.Wales
Thanks guys, I will add these tomorrow and I will see if it works, I did have a quick blitz through the module itself and they were showing signs of spanning-tree when I did ? so I guess its a test, see if it works, and if there is any bugs but yeah I will add some more nodes
Will try and update tomorrow (aslong as work is not too busy) and provide an update if it's for use for anyone.
