CPU not clocking down after Win 8.1 update
8 Jan 2007
London & Dubai
As title.
Prior to the Windows 8.1 update, my PC would auto adjust its CPU clocks.
after the the 8.1 update CPU is stuck @4.5MHz.
anybody else experienced a similar issue?
sorry, forgot to add PC spec.
i7-4770K
GA-Z87MX-D3H
16 GB DDR3
Wont clock down in Windows.
have now set the BIOS to stock settings and the CPU still will not clock auto down in Windows (remains on the 3.9MHz turbo clock)
A friend had this problem and he reset his bios to default like 3 times then booted, windows then downclocked...he then overcloked as normal and it was OK. Was very odd when he told me.
In a similar boat here. Windows 8.1 and CPU stays on full whack all the way through. (Different setup obviously).
Funny thing is, when I go through the Advanced Settings the minimum/maximum processor state is missing from the options where it is normally found. So I can't even tell it not to use as much CPU power.
CPU-Z just shows the CPU jumping from 1.1Ghz (x12 multiplier) and 3.7Ghz (x37 multiplier) (CPU is 3820). I'll check for a Bios update to this (Asus RIVE), but this seems really weird.
Did a straight upgrade and not a reinstall, so that might have impacted on a few things.
Even so when you go to advanced settings, what is the minimum processor state set at?
Yep even after I have set the advanced settings.
minimum CPU state is set to 5%, but I have tried all sorts of settings combinations.
Was all working well before the 8.1 update.
I'm stumped
The Windows 8.1 update done some odd things to my machine. Had to blank it and start from scratch and put everything back on. Aside from a couple of reg edits it was working like Windows 8 again after this.
