I'm also looking at getting some LED striplight stuff to go int he new kitchen, generic chinese stuff from eBay ok or has anyone used a specific seller that they would recommend?
I've been looking these, to go under some shelves to light my desk area up a bit more.
They come with a 5 year warranty.
http://www.ledhut.co.uk/led-strip-lights.html
Not too expensive considering they include a 5 tear warranty, think this maybe wheat I end up with!
Handy as the bench runs are 2.4m hehe
How many strips can I connect up to the one transformer?
Any thoughts on these?
http://www.ebay.co.uk/itm/Ledlam-GU...08?pt=UK_Light_Bulbs&var=&hash=item27d2bc7fe0
Uk branded with 2 year warranty 10 for 36 quid inc postage? Anyone tried them?
GU10 – Philips 6W Perfect Fit Dimmable Very Warm White (40°)
- 300 Lumens
 - 2700 Kelvin
 - 6W
Flood – 70W Day White
- 6,000 Lumens
 - 6000 Kelvin
 - 70W
Has anyone done a straight swap of GU10 LEDs to replace regular GU10s, on a standard dimmer, and they've behaved well?
Reason I ask, is in my only experience of LED GU10s on a dimmer, we had to get one dedicated to LEDs to get a decent dim effect across the range of the dimmer.
Standard dimmers do not behave properly with led lamps,ie flickering, you need a trailing edge dimmer for the led lamps to function properly as you have found.
Varilight V-Pro switches among the best, have one of the lowest minimum load settings of all, just 10 Watts.
Photos
.  I've bought more of the Philips GU10 now - they're great!
Got to Asda yesterday,they only had a triple packs left,which were the non dimmable version.
Will try to go to the other Asda at Cribb Causeway this week & see what that have.
