Any idea what voltage controllers are used too?
So what's everyone expecting from their new purchase clocks-wise? Looks like clock ranges may be similar to the 7970, with ~1200mhz on air ~1300mhz+ doable on water.
Some of you are in for a beastly upgrade, I moved from cf7970 to a single 780oc and without fraps running I can't tell any difference - which in a round about way is a good thing![]()
Just a note about fan profile and throttling, you will need to set the fan max to 100% or possibly miss out on quite a few FPS:
http://www.hardocp.com/article/2013/10/23/amd_radeon_r9_290x_video_card_review/13
They said it only went up to 65% in reality though.
I expect they'll be a way around that somehow. Probably just needs time for everyone to get used to the new way things work with this card.
Yep hopefully a custom BIOS that doesn't have any boost/turbo rubbish.
Now only 9 hours at work Go back home drain my water loop take 7950 out. Fill the loop and testing time begins.
Best thing is when blocks arrive will do it again but need to clean my CPU block. I bet its got some oxidation inside cause temperatures are not what they used to be. Not looking forward to that bitRemember boys and gals EK nickel block + kill coil = NO GOOD. Sticking with normal one this time heh.
