Received mine this morning and had to send it back.
Its said the cooler is 66db at full whack. which doesn't necessarily bother me. but I kid you not the coil whine was louder than the cooler. It had coil whine at any sort of load which was louder than the cooler. There was no coil whine at idle. but as soon as any sort of load was put onto the card. It just screamed with coil whine.
Such a shame. I'll have to see if a different batch comes out later on, as I've read a lot of reports of coil whine.
Also when removing the card. I know the card runs at 95c. but OMG. the shroud (plastic) was near melting point. I couldn't touch it for a good 10-15mins after shutting down. I burnt my thumb.
Every other GPU I've had has never been anything like that. I could switch my system off and instantly remove it without the card even feeling remotely hot.
Score P16581
AMD Radeon R9 290X(1x)
Intel Core i7-3970X Extreme Edition Processor
Graphics Score 17135
Physics Score 16382
Combined Score 13544
http://www.3dmark.com/3dm11/7377071
Check the graphics score.
LtMatt put the hanky away.![]()
Very nice Kaaps - what voltage for those clocks please?
MjFrosty had a look at stock memory clock i get artefacts at 1050+
Highest setting without artefacts is 1035mhz on core. Well now 35mhz over standard i cant even call that overclocking.
Only hope is bios
1.375v
I have had the card up to 1200/1575 in Firestrike using the same volts.
Watercooling should help more.
Is the Asus BIOS available for download anywhere Gibbo?
No probs, I'll track it down and then post it into the OP for future reference.I've posted the link a few times in my threads, can't remember where, your gonna have to search buddy.
I have decided to return mine and await a better cooler. The card itself is fantastic but the cooler is awful. After half hour of BF3 the fan noise is horrendous and very intrusive. I could not use this in a system for someone and after hearing the noise they have gone for a 780.
Bit of a shame AMD cheeped out on the cooler. I will order again when there are better coolers available.
Firestrike Scores for one and two cards
Score 11388
AMD Radeon R9 290X(1x) @1200/1575 Air Cooled
Intel Core i7-3970X Extreme Edition Processor @4.9 Water Cooled
Graphics Score 12731
Physics Score 17754
Combined Score 4891
http://www.3dmark.com/fs/1047254
Score 18896
AMD Radeon R9 290X(2x) @1180/1575 Air Cooled
Graphics Score 24063
Physics Score 17705
Combined Score 7530
http://www.3dmark.com/fs/1047412
