Who needs screw holes when you have thermal adhesive?
I will say that getting that off is a fair bit more difficult than the little ones due to the shape though...
RIP RAM Chips.
Actually there is a 200mm fan blowing on it as well from the case side. I just looped a bench for a bit and the heatsinks were not too hot to touch. I'd imagine the reference cooler is heating them up from the GPU core rather than cooling them down.
I've always found that to be a better set up than a full cover block, as long as the air flow over the card is really strong, which you seem to have. Core only blocks give better core temps than full cover blocks and those heat sinks are more than capable of dissipating heat from RAM and VRM chips.
Only shows GPU temp, no VRM temps.
edit:
What CPU are you cooling in your loop and what is the overclock on it?
I've been looking at buying a custom loop for a bit and have been undecided how on many radiators i need. If your doing this with a single 360 on the 290x and cpu with overclock i guess i've been underestimating the single 360 rad idea.
Thanks for this thread!
I am currently running 3 6950 each with a raystorm GPU. The FPS is great, Crossfire Quality is sometimes so-so.
I was thinking of getting the r290x as it should offer roundabout the same performance as my current setup, but I didnt want to get a new cooler.
The R290x still falls short off the performance I am wishing for, but I am sick of CF. It's not that bad, but sufficiently bad that it gets annoying.
So probably the R290 or maybe the r290x should be my saviours until sometime next year I get an SLI GTX 870 setup.
That combined with a g-sync monitor should offer smoothness, not seen by CF.
I have a MO-RA 360 with 9 Noctua NF-F12 BTW THE BEST fans out there for a rad with no competition
So cooling should be no problem. Don't think a r290x produces much more heat than 3 6950.
RIP RAM Chips.
single 360 for a 400w GPU and a CPU? lol
You assume too much... The vram heatsinks were attached with akasa tape.
Best fans out there for radiators are Gentle Typhoons, not Noctua's
Whats your problem? Do you actually have something constructive to add to this or is this all we can expect from you?
Well let me rephrase that.
The NF-F12 (and only these specifically) are are superior to the Typhoons in low rpm (150-500) situations, especially concerning noise.
I had some Typhoons and I did not like the low rpm sounds they made at all.
The Typhoons might have a better performance at higher rpm (although if so, I can't imagine by much), but start up voltage was a problem for me, too.
The NF-F12 have no problem also starting at ridiculously low voltages and the PWM is utterly silent.
But let's just agree that both are super fans, but I still stand by my opinion that the NF-F12 have a significant edge concerning low RPM performance
You only have 3 posts, so I'll let you pass this time, but you're still wrong.
OP - got any sort of thermometer you can measure the VRM temps with? Would be interesting to see how hot they get
You think i assumed that the tiny heatsinks weren't attached just dropped on top of the chips?
No, I assumed that you thought I'd used glue on them. So how about you explain your 'RIP' comment? Because it makes no sense.
Why do you have such an attitude problem? It's getting pretty tiresome.
