Caporegime
- 17 Oct 2006
Order placed and appointment for next Friday am.![]()
Sweeeet!
Just make sure you're in!
Sweeeet!
Just make sure you're in!![]()
Well... since having switched a month ago:
FTTP gives better pings than FTTC. Something like 10ms instead of 25ms. So it's handy for gaming, but not a big deal.
300MB vs 80MB isn't such a big deal, most servers aren't capable of serving at that speed anyway. Only things like Steam, torrents, newsgroups can take advantage of it - but then it's a case of downloading something in 1 minute instead of 3 minutes... either way you boil the kettle and it's done.
So... going FTTP is cool, but going for the top package isn't.
Do I have to use the Home Hub that will come with my installation or can I continue to use my Netgear DGND3700 which has a Gigabit port for connecting to external cable/fibre modem and has many options which I would like to continue to use?
EDIT: Just checked my order and a BT Home Hub 5 is on the way. I presume that they now won't be installing a VDSL modem as well?
You can use the DGND3700 WAN port.
Username: [email protected]
Password: 12345
The engineer should provide a VDSL2 modem.
Was talking to a Guildy last night on Vent who has just got SKY Fibre (supplied by BT). He gets full Torrent download speeds 24/7. Why are downloads capped for BT users, but others using the BT network get full speed? It's BS.
Sky Fibre uses Sky's network.
You'll need to re-contract if you want to remove the shaping.
What is it precisely that I need to ask for?
We haven't had the service a year yet and shaping was never mentioned as something you could opt out of, or I would have done it at the outset![]()
mines been avaialable since June but my cabinet's not been upgraded. Was supposed to be September now Jan.
