Battlefield 4 Thread ~ Server details in opening post ~
Starting to get itchy feet here, bought from simplycdkeys last week (never used them before) and because I signed up with a different email to the wifes confirmed paypal address, had to jump through their "confirm payment" hoop.....all went fine but paypal is still showing my transaction as "pending"
Getting worried now because I see some of you have had monies taken from paypal accounts already and I dont want to end up with no code come release day :mad:
Tried all that. Ordered 27th march via origin store. After connecting to korea vpp via flyvpn and starting up origin bf4 still greyed out and unable to pre0load.
took my mate 5 or 6 tries till it finally worked. then disconnect use normal connection.
MINI TUTORIAL - How to preload
1. Download FlyVPN - http://www.flyvpn.com/files/downloads/FlyClient_3.0.1.8.exe [flyvpn.com]
2. Login and code - http://www.flyvpn.com/freetrial. [flyvpn.com]
3. Connect to korea, if it doesnt connect on the first try, just try again..
4. When it goes green, go and open up origin and start downloading.
5. After the download has started, turn of FLYVPN and the download should continue with full speed.
Do you pause the download at step 5 after starting it successfulyy THEN switch off VPN and continue?
OR
Switch off VPN whilst mid download (ie. dont pause)?
2 things that people seem to find impossible to do....
1. Read the whole OP in the links I have provided. The originals not just Copy paste DG..Oh and how is your ESL team going?
2. Press back 1-2 pages.
Trying to help you guys but please, help yourselves by engaging that funny lump inside your skull.
So to recap
How to preorder via Mexico - It helps if you actually read it. ie why is it showing in dollars etc....
If you pre ordered from Origin UK, / pre ordered before July you cannot pre load early.
VPN trick for pre loading - Be aware only disconnect the VPN once DLing do NOT logout of the VPN straight away if you are having issues like meths, it can time out that way. You can ofc logout after a few moments but if you logout instead of disconnecting the connection my time out
Also a potential problem with Windows 8.1 and high input latency through directinput unless thats been solved - not sure if BF4 has an option to use raw input and/or whether it uses directx for input at all but it would affect other games even so.
1. It only affects older games ie COD4
2. For some reason in the beta RAW off was actually RAW on LOL so it was back to front :D
it hasnt been solved on win 8.1 lol dont say that as you have people reinstalling op systems , dont mind a laugh but that aint fun.
it effects many games including bf.
Using this old trick should enable you to preload/unlock BF4 earlier.
Step 1: Get Fly VPN
Step 2: Using free trial accounts (listed on the right side on the free trial page) login to Seoul VPNs (It's in Korea, for those who did not like to study geography).
Step 3: Fly VPN might ask you to install some drivers (seems important)
Step 4: once it confirms you're connected start origin - this may take a while.
Step 5: once you successfully log in, enjoy!
Step 6: once the preload is availabe, simply start it and wait for the download to begin
Step 7: once the downloading has started, close origin and log out from fly VPN - from now you can continue downloading using your normal network
So to recap
