- 29 Jul 2007
- cornwall
So bf4 is around the corner 780gtx has had a price drop what of the two cards would oeople recommend for bf4
Will the 780 play it in ultra setting's
The heat/noise of the 290X is being overstated.
Fact is though, after selling the games a pre overclocked 780 matches a 290x for around £70 less. You also get the advantage of a cooler, quieter and less power hungry card to boot.
Only fly in the ointment is mantle but you will have to wait till December to see if that makes much difference..
With the free games and the 780 now being cheaper, I would go for a 780. They will both perform great in BF4 and I expect when Mantle is released in December, the 290X will have the better frames. The beta performed very well on a 780 and unless you are anal about having the fastest and watching the fps all the time, you wouldn't notice what was in your machine, so for price and free games, go for the 780
You can always sell the games as well, which would make the card around £50 cheaper.
You seam to be leaning to a 290X and looking for confirmation Jon.... Go for it. It is a great card and performance is there. Ignore the heat and noise things you are reading, as it is just payback for the GTX 480 launch![]()
True audio and support out the box for DX11.2 are also worth a mention. They are great selling points on the 290 series.
Right now go for the 780, its the cheaper of the two and the reference cooler on the 290X is not to good, with board partners coolers a little way off yet.
