Was planning to buy this week got new bundle coming this week and at the moment 580gtx is struggling on medium setting with 100% res scaleing
290 going to be slower then 290x ?
True audio and support out the box for DX11.2 are also worth a mention. They are great selling points on the 290 series.
is kepler not compatible with DX11.2? I thought any decimal iteration of DX would be supported by cards that supported its base so in this case any card that supports 11 will support 11.2? I could be wrong but I hope not![]()
780's can be had for under £365 with the games if you shop around.
What Humbug said.
I personally don't care, as I remember dx10.1 bringing so much to us gamers![]()
DX11.1 and 11.2 is different to DX11
Kepler supports most of DX 11.1, all the most important bits i think, just not officially as its not "full support"
DX11.2, i don't know, there may be some support, what or how extensive. i don't know.
What Humbug said.
lolas above.
290X if you're not overclocking or care about high temps and noise, GTX 780 if you do.
