31 Oct 2013 at 10:08 #1 snips86x snips86x Soldato Joined 14 Nov 2012 Posts 17,973 Location Chesterfield Can anyone recommend some software which will convert a video file to an FLV without reducing the quality of the video?
31 Oct 2013 at 14:34 #3 snips86x snips86x Soldato OP Joined 14 Nov 2012 Posts 17,973 Location Chesterfield dmsims said: Try Handbrake Click to expand... Thanks for your input dude, unfortunately, the software only puts out to MKV & MP4.
31 Oct 2013 at 14:50 #4 dmsims dmsims Associate Joined 17 Jan 2003 Posts 1,109 Sorry complete brain fade Got ahead of myself (used Handbrake to change all the FLV to MP4!) Before that I used Super Video convertor (for FLV)
1 Nov 2013 at 23:04 #5 FunkyCowie FunkyCowie Associate Joined 31 Dec 2004 Posts 1,384 Location Essex, UK I used to use this... http://www.rivavx.com/index.php?encoder&L=3
1 Nov 2013 at 23:41 #6 Phantom Shadow Phantom Shadow Associate Joined 5 Jun 2013 Posts 1,531 should be able to do it in ffmpeg, and play around with the quality settings to get what you are after.
6 Nov 2013 at 10:42 #7 snips86x snips86x Soldato OP Joined 14 Nov 2012 Posts 17,973 Location Chesterfield FunkyCowie said: I used to use this... http://www.rivavx.com/index.php?encoder&L=3 Click to expand... Thanks for this! I have had a quick look and it seems great, but the inbuilt player does not work and I'm unable to run in VLC or find a suitable FLV player. Phantom Shadow said: should be able to do it in ffmpeg, and play around with the quality settings to get what you are after. Click to expand... I've downloaded this but there is no instruction on how to run it. It's just a download with a list of files and folders, not sure how it works.
6 Nov 2013 at 17:02 #8 Phantom Shadow Phantom Shadow Associate Joined 5 Jun 2013 Posts 1,531 I think it should be quite easy to do with ffmeg, ill get back to you tomorrow on how when im back at my computer
6 Nov 2013 at 17:06 #9 Magik5 Magik5 Associate Joined 19 Feb 2009 Posts 137 Just as an FYI, Flash Player supports the h264 format now in videos with either .f4v or .mp4 extensions. Check out Adobe Media Encoder as another encoder option
7 Nov 2013 at 11:41 #10 Phantom Shadow Phantom Shadow Associate Joined 5 Jun 2013 Posts 1,531 The following should help get you set up with using ffmpeg: http://blog.superuser.com/2012/02/24/ffmpeg-the-ultimate-video-and-audio-manipulation-tool/ Then you should be able to use the following commands to convert to flv http://stackoverflow.com/questions/...t-mp4-video-file-into-flv-format-using-ffmpeg
7 Nov 2013 at 16:35 #11 AtaRo AtaRo Associate Joined 4 Aug 2008 Posts 2,084 Have you tried VLC to convert the file. I have used VLC to convert videos and captures streams.
7 Nov 2013 at 23:50 #12 thedazman67 thedazman67 Associate Joined 24 Apr 2004 Posts 2,059 Location Warrington, UK https://cloudconvert.org/ never used it personally but I know others who have and they recommended it.
8 Nov 2013 at 00:33 #13 ikillbears ikillbears Soldato Joined 5 Feb 2006 Posts 3,524 mpeg stream clip is what i use
