- 22 Apr 2011
- Nottingham
He's using Win 7 IIRC. Really not a good idea for this game.
w7 x64 here and it runs smooth as butter, Just the crashing every 15 mins
so the i5 4670k is not going to be the best? i got a 780 to go along with it
Played a couple of hours now and really smooth without a single in game crash ... had to kill the exe a couple of times on leaving the game though! Could not find busy servers an a couple of occasions as well. Only technical issue I have with in game is that the sound is weird and kind of choppy. FPS is well over 100 mostly with some scenes dipping into the 90s .. tbh overclocking is not required on my setup! Graphs below of average GPU usage per core and average CPU averaged over 12 threads ..... the third graph combining both sections looks at CPU only showing Max loaded thread, Min loaded thread and average thread load ..
Nearly linear scaling with clock speed, clear sign of being CPU bound.
What program are you using to create those slides?
Look like Excel ones to me?
The GPU not maxing out could be drivers, can't say it's a bottleneck unless we see other results.
You don't need 100% CPU usage to get a bottleneck.
It could be maxing the parts it can max (Ergo, the bottleneck is down to the shared resource, the FPU, which is maxed out)
It has 1 FPU to 2 cores.
It's pretty logical that you can max out the FPU performance it can give without maxing out all cores.
But again, it could be down to drivers.
Very nice, I'm guessing there's little to no stuttering on that setup judging by the graphs.
No stuttering .. Beta was terrible on ultra on these GPUs on my 920@ 4.2ghz. The Shift to 4930k, windows 8.1 and probably some game engine improvements have saved the day, lol!
lol, I bet you're glad it is performing noticeably better than your old CPU, as it's pretty expensive upgrade. The CPU alone cost's more than a CPU and motherboard usually does. Would love one but think I'll treat myself to one of those Ezio 240Hz monitors next.![]()
Carried over my TRUE cooler and RAM to keep the wallet hit down a bit as well ..
Not sure I'd agree, not seeing anywhere near 100 % CPU utilisation on any core even at 4.6 GHz. The gains are small with higher CPU clocks on the 8320.
Look at the numbers - CPU speed goes up 8%, so do the FPS, ergo, bottleneck.
