- 2 Jan 2011
- Bristol
Sorry to bring up a topic that has been discussed to the earth and back but I didn't really want to jump in someone else's thread and have a bit of a unique slant.
I've got to the point where my Q6600 just won't cut it anymore. Well I say that, more over I've got to the point where the limitations on memory just won't cut it anymore as even after 7 years my Q6600 is still going strong. The board I have at the moment maxes out at 2gb over 2 slots with DDR2 and finding another 775 board, let alone one that would be up to snuff is next to impossible.
Now I only use my rig for mid to light gaming and for work (Illustrator, InDesign and Photoshop roundtrip) so nothing even remotely CPU taxing. The problem comes in that a 96+ page InDesign document will run out of memory and crash 2 out of 3 times after 5 to 10 mins (even with previews set to a minimum). So I need to go 4gb, preferably 8gb but the rest is just to the confines of my wallet.
Ideally I was looking at a 3570k Ivy or due to having a near 20 hour a day up-time a 4670k Haswell for the lower power options. After getting clued up on all the differences and talking to a friend I was told if I intend to overclock that both Ivy and Haswell run quite hot and to run a decent and stable overclock that you'd either need to get really lucky with the silicone or go for a water cooling solution.
Now just to upset the apple cart even further he said he has a new 2600k and a couple of new 2700k's he would be willing to sell me. Both are way more than I need but I've been assured that Sandy's are a lot let of a lottery and are much better on heat if I wanted to go for higher clocks.
Anyway this has left me all a little unsure of the best step forward.I'm actually leaning towards taking him up on his 2700k over an Ivy or Haswell. Though I don't want it to seam like I'm coming here for advice to buy a CPU off of someone else as I'd still need a motherboard, ram and a CPU cooler.
Give the choices and with my requirements what would you guys suggest?
Any advice would be most appreciated.
