Grudas LOG WAT
12 Mar 2008
West sussex
Time to start my log!
First day at gym 03/01/2013!
Started off with the usual "I know better I'll do this and that" routine which got me nowhere after a 3months I got my arse whooped in gym rats thread and went with Strong lifts 5x5! :)
Starting weight-;
Squats - 40kg
Bench - 30kg
Deadlift - 70kg
OHP - 30kg
Bent over row - 35kg
Current PB's - updated 01/02/2015
Squats - 140kg
Bench - 85kg
deadlift - 170kg
OHP - 60kg
Bent over row - 80kg
Routine -;
started with 5x5 stronglifts, but bench presses never worked for me and for some reason I couldn't increase the weight properly and I've struggled with it since.. Deadlifts while 1x5 was OK it never felt enough and that's cool I went along with it for a few weeks fallowed the routine but now that has changed too, added dips, chinups and lat pull downs.
So he's my current routine A and B
Day A
Bench press 5x5 - 2 sets on lower weight 3 on max working weight
chin-ups - 4x5(warm up)
deadlifts - 3x5
BW dips - 5x5
Lat pull - 5x5
OHP - 5x5
Squat - 5x5
Day B
Bench press - 5x5 - 2 sets on lower weight 3 on max working weight
BW dips - 5x5
Lat pull - 5x5
Squat - 5x5
Bent over rows - 5x5
And now my stats -;
Height - 5'9
weight - 75kg
age - 22
Goals by end of 2013 -;
Squats - 150kg
Bench - 85kg
deadlift - 170kg
Pics(I know my posture is really a mess when taking pics) -;
I train on Tuesdays/Thursdays and Saturdays, Ill try to keep the log updated mainly for myself so I can keep track of my training and to hopefully get some feedback as I go along.. :)
going for more KOM's ?
Good luck mate, hope you get to your target
got 10! but lost 2 not long ago, one due to gps bug and I can't flag it for w/e reason.. and one was taken away by a mate but I rarely if ever ride that road now so I need to get out of my way to get it back!
Can't say that squatting from 40kg to 140kg has changed much about my cycling really! I may have stronger/longer lasting "surges" of power since I started training but nothing else! :)
Good luck with yours! :)
12/10/2013
Bench press -;
8x62.5
8x62.5
8x62.5
1x77.5(PB!)
10x52.5
10x52.5
Bent Over rows -;
5x70kg
5x70kg
5x70kg
5x70kg
5x70kg
Chin-ups
5(slow)
5(slow with a pause at the last one)
5(slow)
BW DIPS
5x5
Squats
5x100kg
5x120kg
3x150kg - chickened out and couldn't go low enough
5x 120kg
5x100kg
5x100kg(A2G)
Lat pulldown
86kgx5
79kgx5
73kgx5
66kgx5
59kgx5
52kgx5
Happy with bench press! should have tried 145kg on squat! :) come next Saturday I'll give it another shot at 145kg!
15/10/2013
went a bit mental on volume when it came to bench presses because I had to share the rack so had to make my self busy during the time! legs felt weak, so did shoulder presses.. deads were ok, chins, dips lat pull etc was fine too.
Bench press -;
10x50kg
10x50kg
10x60kg
8x65kg
10x55kg
10x55kg
10x50kg
10x50kg
10x50kg
BW Chin ups
5x4
Deads
5x130kg
5x130kg
5x130kg
BW Dips
5x5
Lat pull
8x66kg
8x66kg
8x66kg
8x66kg
8x66kg
Shoulder press
5x45kg
5x45kg
5x45kg
5x45kg
5x45kg
Squat
10x50kg
5x95kg
5x110kg
10x90kg
10x90kg
front squat(first ever attempt)
10x60kg
legs gone..
17/10/2013
Felt tired from the start, legs were aching due to pushing hard on my way home from work - 9mile cycle.. So I didn't expect much.
Bench press -;
15xbar
8x65kg
8x65kg
8x65kg
10x55kg
10x55kg
Bent over rows -;
5x70kg
5x70kg
5x70kg
5x70kg
5x70kg
chinups
5x4 narrow grip
5x4 wide
5x4 narrow
5x4 wide
dips
bw+6kg dumbellx5
bw+6kg dumbellx5
bw+6kg dumbellx5
bw+6kg dumbellx5
bw+6kg dumbellx5
lat pull -;
8x66kg
8x66kg
8x66kg
8x66kg
8x66kg
squat -;
10x60kg
5x100kg
5x110kg
5x120kg
10x90kg
10x80kg
front squat
5x60kg legs gave up..
KTHXBYE
19/10/2013
and what a bad day.. felt ill from the start so I knew I won't be able to push hard.. legs were in pain but did as much as I could even tho the squats were not as low/stable as I wanted :( Just need to keep pushing and ill get there.. genuinely one of the weakest days I've had! deads felt fine tho! bar the awful belly ache.
Bench press -;
15xbar
10xbar - narrow grip
8x65kg
7x65kg failed on last rep
2x65kg
8x65kg
10x55kg
10x55kg
15x50kg
chin ups -
5 wide
5 narrow
5 wide
5 narrow
Deadlift -;
5x132.5kg
5x132.5kg
5x132.5kg
Dips-;
5x with 6kg dumbbell
5x with 10kg dumbbell
lat pull
8x66kg
8x66kg
8x66kg
8x66kg
8x66kg
Shoulder press - will add 2.5kg next time
5x45kg
5x45kg
5x45kg
5x45kg
5x45kg
Squat -;
10x50kg
5x100kg
5x110kg
5x120kg
5x100kg
10x90kg
front squat -;
10x60kg
10x50kg
Nearly 14tones shifted.. eh
Ok day yesterday but increased weight on bench presses killed me..
Bench press -;
15xbar
8x67.5kg
7x67.5kg(failed on last rep)
10s rest
3x67.5kg
7x67.5kg(failed on last rep again bo)
10s rest
3x67.5kg
10x57.5kg
10x57.5kg
10x52.5kg
10x50kg
10x50kg
Bent over rows
5x70kg
5x70kg
5x70kg
5x70kg
5x70kg
Chinups - went a bit mental on these due to the fact that both lat pull machines were surrounded by 10guys sharing them..
5xBW - Wide
5xBW
5xBW - Wide
5xBW
8xBW
8xBW
8xBW
8xBW
8xBW
Dips(felt quite strong on these!)
5xBW+10kg dumbbell
5xBW+10kg dumbbell
5xBW+10kg dumbbell
5xBW+10kg dumbbell
5xBW+10kg dumbbell
Squat(not a bad day tbh)
10x50kg WUP
5x100kg
5x130kg
5x130kg
10x100kg
10x90kg
A bit disappointed with bench presses but It has been my weak point since the start.. Ill work through that weight tho! :)
btw, forever alone here..!? :(
24/10/2013
Not a bad day but my belly was full of weakness gas so that made squats difficult.. I was scared of pooping my self.. some good weight shifted tho and legs feel dead today..
Bench press (fails on 67.5 again.. bo)
20xbar
8x67.5kg
8x67.5kg
6x67.5kg
short rest
3x67.5kg
10x57.5kg
10x57.5kg
10x50kg
9x50kg(fail on 10thlol)
chin ups
5xBW - wide
5xBW
5xBW - wide
5xBW
Deads(felt strong and got commented by a guy that apparently I'm lifting too little for my size?! WAT)
5x135kg
5x135kg
5x135kg
dips(felt really strong and controlled)
5xbw+10kg
5xbw+10kg
5xbw+10kg
5xbw+10kg
5xbw+10kg
5xbw+10kg
lat pull
8x66kg
8x66kg
8x66kg
8x66kg
8x66kg
Shoulder press(finally added weight)
5x47.5kg
5x47.5kg
5x47.5kg
5x47.5kg
5x47.5kg
Squats
10x60kg WUP
5x95kg
5x110kg
5x145kg(done but not low enough to count as full rep so only 2 reps were done properly)
5x110kg
5x110kg
Over all not a bad day bar the fact that we had to stand for 20minutes waiting for the only squat rack in gym to become available..
26/10/2013
low working weight on benches because I had no spotter and with it being my weak point I simply don't want to risk.. so went for more volume on the weight I can handle(drop on my self lol) deads were not in the routine but I did some anyway to see how it felt to go above my working weight and maybe get a PB(didn't get a pb but managed to lift the same weight as my pb)
bench press
20xbar WUP
10x55kg
10x55kg
10x55kg
10x55kg
10x50kg
10x50kg
10x50kg
8x50kg
8x50kg
Squats
10x60kg WUP
5x100kg
5x120kg
5x130kg
4x135kg(Failed on last rep)
5x100kg
BORs
5x70kg
5x70kg
5x70kg
5x70kg
5x70kg
deads
2x135kg
2x135kg
1x155kg
1x155kg
1x160kg
dips
5xbw+10kg
5xbw+10kg
5xbw+10kg
5xbw+10kg
5xbw+10kg
chins
5 - wide
5
5 - wide
5
lat pulls
8x66kg
8x66kg
8x66kg
8x66kg
8x66kg
over all not a bad day.
29/10/2013
Shoulder press -;
5x47.5kg
5x47.5kg
5x47.5kg
5x47.5kg
5x47.5kg
dips -;
5xbw+12kg
5xbw+12kg
5xbw+12kg
5xbw+12kg
5xbw+12kg
squats -;
10x50kg
5x100kg
5x110kg
5x120kg
5x90kg
5x90kg
lat pull -;
8x66kg
8x66kg
8x66kg
8x66kg
8x66kg
bench
10xbar
10xbar
8x67.5kg
8x67.5kg
8x67.5kg
10x60kg
10x60kg
15x50kg
10x50kg
deads -;
5x137.5kg
5x137.5kg
5x137.5kg
chins
5
5
5
5
BOOM
31/10/2013
benches
10xbar
8x67.5kg
8x67.5kg
8x67.5kg
10x60kg
10x60kg
10x50kg
5x50kg
squat
10x50kg
5x100kg
5x120kg
5x105kg
10x95kg
10x90kg
BOR's
5x70kg
5x70kg
5x70kg
5x70kg
5x70kg
chins
5
5
5
5
dips
5xbw+12kg
5xbw+12kg
5xbw+12kg
5xbw+12kg
5xbw+12kg
lat pull
8x66kg
8x66kg
8x66kg
8x66kg
8x66kg
bite me.
no spotter again for the bench press.. bah.
bench
10xbar
10xbar
10x60kg
10x60kg
10x60kg
10x60kg
10x50kg
10x50kg
10x50kg
10x50kg
chins
5 wide
5
5 wide
5
deads
5x140kg
5x140kg
5x140kg
dips
5xbw+12kg
5xbw+12kg
5xbw+12kg
5xbw+12kg
5xbw+12kg
lat pull
8x66kg
8x66kg
8x66kg
8x66kg
8x66kg
shoulder press
5x47.5kg
5x47.5kg
5x47.5kg
5x47.5kg
5x47.5kg
squat
10x60kg WUP
5x100kg
5x110kg
5x120kg
10x90kg
10x90kg
dead.
Dude you started SL about the same time as me and have really progressed well, bit jelly.
thanks man! I started around end of March 2012 and have dropped the weight a couple of times on Deads, squats and benches because I couldn't keep my form! :) but currently the progress is going well.. deads went from 115kg to 140 since Sept 15th! :)
mind you 115kg was easy I was just focusing on form/technique which still isn't 100% at all reps but I'm getting there!
Benches
20xbar WUP
7x70kg(fail on last rep)
SHORT rest
3x70kg
8x70kg
8x70kg
10x60kg
10x60kg
10x50kg
10x50kg
squat
10x50kg WUP
5x95kg
5x110kg
5x120kg
5x120kg
5x120kg
bent over rows(added 5kg)
5x75kg
5x75kg
5x75kg
5x75kg
5x75kg
dips
5xbw+12kg
5xbw+12kg
5xbw+12kg
5xbw+12kg
5xbw+12kg
lat pull
8x66kg
8x66kg
8x66kg
8x66kg
8x66kg
chins
5 wide
5 narrow
5 wide
5 narrow
blah.
tried dropsets-ish for squats these past two days and doms are killing my quads today! was quite fun tho but zero-rest drop sets are really tough in my opinion, abs hurt, quads were in pain and I was nearly out of breath.. once you're done with them legs felt like jelly! will probably keep doing them! good fun.
day 1 -;
chins
5 wide
5 narrow
5 wide
5 narrow
bench press
10xbar
10xbar narrow
8x70kg
8x70kg
short rest
3x70kg
10x60kg
10x60kg
10x50kg
10x50kg
squat - zero rest drop sets
DSet 1
5x125kg
5x115kg
8x105kg
10x95kg
10x80kg
DSet 2
5x100kg
5x90kg
8x80kg
10x70kg
10x60kg
JELLYLEGS..
Shoulder press
5x47.5kg
5x47.5kg
5x47.5kg
5x47.5kg
5x47.5kg
deads (tough as hell after dropsets)
5x142.5kg
5x142.5kg
5x142.5kg
dips
5xbw+12kg
5xbw+12kg
5xbw+12kg
5xbw+12kg
5xbw+12kg
lat pull - out of juice at this moment..
8x66kg
8x66kg
8x66kg
8x66kg
8x66kg
crawl to bench and chill for 10mins..
Day 2
chins
5 wide
5 narrow
5 wide
5 narrow
benches
10xbar
10xbar narrow
8x70kg
8x70kg
8x70kg
10x60kg
10x60kg
10x50kg
10x50kg
squats
Dset 1
5x100kg
5x90kg
8x80kg
10x70kg
20x60kg - failed on 21st
Dset 2
5x100kg
5x90kg
8x80kg
10x70kg
20x60kg - failed(legs all over the place) on 21st :rolleyes:
BORS
5x75kg
5x75kg
5x75kg
5x75kg
5x75kg
dips
5xbw+12kg
5xbw+12kg
5xbw+12kg
5xbw+12kg
5xbw+12kg
Lat pull
8x66kg
8x66kg
8x66kg
8x66kg
8x66kg
<3
an update.. a few lifting days skipped CBA to write it all! :) logging less because I've found an awesome app on my phone that I can keep close and log everything to see how I'm progressing!
Attempted 170kg deadlift and couldn't do it :( dissapointed but I'll give it another shot! squatted 140kgx5 tho but haven't attempted a PR for ages.. guess 145/150 1RM should be possible! we'll see to day or Saturday :)
benches are going fine but some days I literally have no power to get the 8 reps done while the others it feels easier?! random.. but what gives keep lifting and i'll get there!
so here's Tuesdays workout, ditched lat pull downs for now and added seated rows to see how I like them - want my back to work more.
Benches
20xbar WUP
72.5kg x 8
72.5kg x 8
72.5kg x 8
62.5kg x 10
62.5kg x 10
52.5kg x 10
52.5kg x 10
chins - probably going to increase to 8 reps soon.
5
5 wide
5
5 wide
deads - dropped the weight and added an extra set after finding 142.5x5x3 really tough - may have been a bad week.
5x130kg
5x130kg
5x130kg
8x112.5kg
dips - still sitting at bw+12kg, need a belt asap tho.
5xbw+12kg
5xbw+12kg
5xbw+12kg
5xbw+12kg
5xbw+12kg
seated rows
8x52kg
8x52kg
8x52kg
8x52kg
8x52kg
shoulder press
47.5x5
47.5x5
47.5x5
47.5x5
47.5x5
squat
60kg x 10 WUP
130kgx5
130kgx5
110kgx5
110kgx5
110kgx5
:o
Nice work!
Weren't you the guy who came in suggesting he didn't need to do legs because he cycled?
If so, look at you now! ;) :D
If not, then nevermind. :D
