- 30 Nov 2011
After suspicions that AMD sent out golden samples for media loading SweClockers test benches again with a PowerColor Radeon R9 290X directly from Amazon Marketplace at Sveavägen in Stockholm.
The procedure is the same for almost every new launch. SweClockers and other media, products directly from the manufacturers before mass production started, which certainly makes it possible to be an early adopter of the reviews, but also may bring some doubts about that product actually corresponds to what would later show up on store shelves.
With the results in hand, the picture is clear. The performance is basically identical between the press copy and graphics card from the shelf, at least in Uber mode. Any single frame per second is different, which is what may be considered normal as bonds or uncertainty in the measurements.
In the quiet mode, where the dynamic frequencies to work overtime, the situation becomes slightly turbid. A minor performance difference can be seen in some titles, and even if it is not about considerable variations, the trend is clear. In the end, it does an average variance tion of only a few percent, ie no extreme levels. The reason may include slightly less contact with the cooler, or simply easy changing ambient temperature.
Golden samples eh? Tell that to TTL and Linus![]()
...snip..
Absolute rubbish!
We had a press sample card, it did OK, we then got an Asus card and a Sapphire card form our warehouse stock, they both beat the press card in all our benchmarks as they hit higher overclocks.
So without a doubt, complete BS.![]()
Update: As is Tom's Hardware policy, we shared these potentially problematic findings with AMD prior to publication, and the company insists something is wrong with the retail-purchased cards I tested. We will continue investigating and, if any additional news becomes available, update this story.
I read about this late last night. Their retail card was significantly slower than the press card. Pretty interesting.
Can't remember which site I seen it on. I think it was on a 290 review.
