The only important question which never got asked (I wonder why) is the following:
MS recently rejected Mantle in favour of a Direct X 11/12 future so Mantle is only for PC gamers with low end GPU's looking for an FPS boostanyone with a high end GPU Nvidia or AMD will not see much benefit as no publisher is going to only support Mantle as games cost too much to make they would never see their money back !
Great to see Thracks getting stuck in with the community and shows good commitment to their user base. I have not gone over the questions yet but will.
Good thread Matt![]()
I wish the AMD reps were more active here, although it is nice to hear from them when they do post. I think it would be nice to see a Nvidia rep here as well. Then we could have arguments between the two reps.![]()
AMD may well smell but they do show support. I still have a pic of Roy on my dartboard though
Are there Nvidia reps? I can't recall seeing one since, well, I can't rememberAMD may well smell but they do show support. I still have a pic of Roy on my dartboard though
That will stick
Anyone that posts 'holy cow' on twitter is definitely un-cool
According to them, they're not too hot. Loud? At over 50% or so, sure.
The 280X is a 7970, so it's pretty easy to just adapt existing models or make new coolers for those.
...IMO it's nonsense, the non ref coolers can only help the cards. I don't believe for a minute that having a non ref cooling solution in any way hinders AMD or NV for that matter on new cards.
Maybe. I'm not completely convinced either, but I haven't seen anyone with a watercooled 290X posting about the awesome clocks they've reached either. Maybe I've just missed those posts?
But anyway, my main point was that the 280X didn't contradict anything by releasing with 3rd party coolers as it was basically a 7970 and they required nothing more than a lick of paint![]()
95C is the optimal temperature that allows the board to convert its power consumption into meaningful performance for the user. Every single component on the board is designed to run at that temperature throughout the lifetime of the product.
If you throttle the temperature down below that threshold, then the board must in turn consume less power to respect the new temperature limit. Consuming less power means lowering vcore and engine clock, which means less performance.
You want to take full advantage of product TDP to maximize performance, and that is accomplished with a 95C ideal operating temperature for the 290 and 290X.
Even with a third-party cooling solution, like the Accelero 3 some users have started deploying, the logic of PowerTune will still try to maximize TDP by allowing temperatures to float higher until some other limit is met (voltage, clock, fan RPM, whatever).
It's so bloody smart and it kills me that more people don't fully understand it.
It has relevance because you're talking about non-ref coolers helping a 290X and AMD are saying this:
