So I've built up my rig and was eager to press the magic on button, expecting some hiccups.
Low and behold I have at least two.
Firstly: PSU (or at least I think its the PSU).
There is a fairly noticeable grinding noise coming out of the case.
Thought it was the water cooler, but having disconnected it and all the fans, that just left the PSU fan.
Now is this normal for a PSU fan to be fairly loud and give out such a grinding noise? I'm not sure if I am being anal about this or whether this is normal for your average 850W Antec PSU?
Secondly: Aerocool X-Vision Fan Controller.
I have 3 fans connected to it (I didn't connect the CPU fan because it is already being controlled by the H100i water cooler).
All the RPM values go up only to 1000 RPM and voltage is 12V.
If I turn down the RPM by 100RPM increments, it does so down to 600 and then from 600 to 0.
Further, when it gets to 600, the fan turns off and the voltage drops to 0V.
So theres no, "inbetween". Im a little confused about this.
Shouldn't the RPM values go up to 2000 RPM and the like? And shouldn't the voltage drop incrementaly as you decrease the RPM levels ?
Apart from that, Im quite happy with the fan noise level, quieter than I thought, its just the damned PSU!
