JUst so you know "only" 3GB is visible to Games on the 7990.
Haha true
290. Surely 290X will be better for future games?
personally I go with recent tech if I upgrade.
better support for games and OS down the line.
Both the cards in question are 28nm and fully support DX11.2. Tech is as latest as it gets.
i keep seeing the words "future proof". no such theing its a moving target that cannot be hit
True but you rather be closer to the moving target than further away and buying a 7990 over either 290's is further away.
Thanks Kaap, much appreciated.
As always the price vs performance on Nvidia cards means i won't consider them. However the main factor is Battlefield 4. I will put a thousand hours or more into this game and to get the most performance possible from it ill need an AMD card and Mantle.
I have good airflow and generally reference coolers are best for crossfire in my experience. Excluding my current His Ice-Q 7950's which are excellent together because of their quiet blower type cooler.
However if you buy a 290 or 290x now then you're going to have to live with that noise. Well, that or take off the cooler and invalidate your warranty. I just don't see the point, given the 7990 is so quiet. I mean honestly, it's so quiet I can't hear it over my 120mm Cougar fans which are the noisiest fans in my rig. And they're supposedly pretty quiet.
uksoldierboy, what rpm does your fan spin at?
After seeing Kaapstad's PCI-E testing I'm a bit more tempted to go with 290 XFire, but I'm not sure about the noise.
I had 7970 crossfire a while back and I could hear it halfway down the stairs![]()
Around 2900rpm pal. That's only when gaming though, if i'm just browsing on here, or maybe watching a movie, i have the fan @20%.
