Would be nice to sell 3 titans, buy 3 Ti's and have spare change for beer!
That would be the worlds best upgrade.
The problem is they would be totally useless on three 1600p monitors with their 3gb of vram.
The new Maxwell Nvidia GPU's will be out in a few months and seeing as you obviously have money to burn id wait for those to come out as getting triple 290x's or 780Ti's will probably net you minimal frame increases. im an AMD fan but will be good to see how nvidias new architecture will be
Yeah, give Crysis 3 a go![]()
3.5GB is lower than I'd expect on the Titans, seeing as BF4 caches quite heavily!![]()
I think you're making the right choice for your setup regardless. 3/4GB is a thin line at that resolution![]()
Nonsense! Whack up the settings to max in Crysis 3. What's the point in having all that hardware if you can't max it out![]()
hence the question on which horizontal res for a 1080 screen above I'd get away with.
I'm gonna stick with the Titans after everybodys advice here. Thanks again.
I finally got back into a bit of gaming after being out for nearly 2 months and out of curiosity I did a few tests over the weekend with BF4. With most settings on high (not ultra), GPU mem usage averages just over 3.5GB on 7680x1600. So that would rule out the the 780ti's and be cutting it too fine for the 290Xs anyway.
However frame rates varied wildly, from just playable to just too choppy and it just wasnt a comfortable experience at all. Going to the pause menu would crash the game and a hard reset was required.
Switching to a single 1600p monitor and I was getting avg frame rates around the 120 mark with all settings on Ultra so that just fine. (no overclocking on the GPU's for this test)
Last/current gen games until recently were very playable on 7680x1600 with some settings dialed back a bit. It begs the question as to whether the new games, and I'll include BF4 in that, are just too much even for 3 Titans to push around at good framerates despite their memory capacity.
One monitor is fine but I'm kinda reluctant to loose the 3 monitors as I much prefer that experience. As I mentioned in an earlier post, I most certainly underestimated the demands 3 1600p screens would place on the system.
One option would be to keep the 1600 screens until Maxwell comes along and in the meantime get 3 1080p screens which will allow me to play with decent framerates. I should be able to sell them on once I can go back to the 1600 screens. I'm basing all this on the premise that all next gen games are going to be as demanding as BF4 proved to be over the weekend.
One more test that I havent done is to repeat the above with some overclocking on the GPU's. I did this before on past games but results were mixed with some games fine and others crashing with certain overclocks.
Seems like a lot of hassle considering what you've got already.
If you find time it would be nice to see some performance numbers from Fraps with what you've got now though.
Tri SLi scales well if you disregard the awful bottleneck at 1080. Quad SLi has never scaled that well though, and has negative impact more often than not.
