Virgin Media Discussion Thread
It will be yeah, i wouldn't count on them upgrading the upload at the same time though. It took them forever to do that with the last round of speed bumping.
I wouldn't count on them doing the upgrade between March and May either. The did a similar thing with the last speed bump. Announcing it way before it was planned to happen and that date for me was nearly a year behind the original planned date.
It appears that BT getting the Champion League rights has put the willies up VM.
Edit. What my update is scheduled between. Nicely coinciding with when my contract expires.
Hmm, according to VM's FAQ on this the upload is not increasing with the download. A complete waste of time for the 120mb customers in that case.
http://community.virginmedia.com/t5...nounce-Even-Faster-Broadband/m-p/2060120#M171
I agree. The 126Mb will increase to just 145Mb (19Mb extra) with no upload increasing. So, pointless to sign up 12 months contract. Virgin Media is tight git ******* on the upload. They never interesting on the upstream. Beware of 6.7% price increasing for February 2014 also.
Ah so not sticking with the 10% upload policy for now. So pretty much just smoke and mirrors upgrade.
Some of you might find this post of interest in reference to an earlier discussion...
Ignition said:
Okay. Perhaps you could explain for me how Comhem in Sweden are selling 30-50Mb upstream on a EuroDOCSIS network, 65MHz subsplit, or how Comcast in the USA sell 25/5, 50/10 and 100/20 on a US DOCSIS 42MHz subsplit network?
I'll answer my own question. They use more and higher capacity channels - the Superhub can handle 108Mb of upstream capacity in a service group.
At present VM's standard build is 36Mb to a group in the form of 2 upstream channels, however they are working towards increasing that to 54Mb in 2 channels and can also bond the 3rd DOCSIS 2 upstream channel which is present in some areas to deliver 81Mb via 3 channels to a service group.
The restricting factors are that more channels means lower maximum transmit power, so modems have to be 'lined up' on the network differently, less attenuation on the return path, and SNR, higher order modulations require better SNR, 3dB per exponent increase so moving from the regular 16QAM to 64QAM, 18Mb per channel to 27Mb per channel, requires 6dB better SNR.
Another potential issue, though this won't be such a big deal given most of it should have been dealt with during the move from DOCSIS 1.1 to DOCSIS 2 upstreams, is the capacity of the upstream lasers. More and higher order upstreams means more power input to the lasers from the coaxial part of the network, and some older fibre optic nodes with legacy transceivers may struggle and need replacement.
So the keys are ensuring the network is clean enough, through busting ingress and fixing rogue plant, to carry the maximum 4 6.4MHz upstreams at 64QAM, ensuring the network is properly lined up so that modems aren't pushed over maximum transmit power by the increased number of upstreams, and ensuring that the fibre nodes have the transceiver to carry the channels.
The first 2 of those are actually routine network maintenance, if the network isn't kept clean and properly lined up the fault rate goes up as it becomes inadequate for current demands, only the 3rd is exceptional.
It's for the most part about blokes in vans doing the maintenance, not about upgrades, hence labour costs not capital expenditure.
They can do it, it just costs money. Without the business case to increase the urgency it's an 'as and when'.
either my hub is dieng or their having issues in my area for the past 5 days I have had random disconnects when I run diagnostics I get
Windows can't communicate with the device or resource (primary DNS server)
Its getting really annoying when it happens on battle field and im actually positive KD lol
Got a Draytek 2820n to use as my router and put the Super Hub in Modem Mode. Will this be easy to setup? I only have my Xbox 360, PC and Rasberry Pi with static IPs.
6.7% increase seems to be correct.
free my ar....
this is the last time they can do this and customers have to take the hike on the chin they say: http://www.bbc.co.uk/news/technology-24911042
